03-29-2006
It's hard to say without seeing it, but a 1980 Buccaneer 272 wouldn't be worth much in average condition. If you have to put new or used sails on it and a new or used motor, and have to pay to have it hoisted out of the lake and hauled to where you can work on it, as well as your labor and materials, you can pretty quickly have more invested in it than it's worth. If the decks or coach roof are rotten or waterlogged inside, then it's not worth salvaging. If there's no hidden structural damage or rot, it might be worth doing, but the only way you can know that is if you have it surveyed by a good surveyor, and that would add a few hundred dollars to your up-front costs. It doesn't sound very promising. I think you'd be better off buying an older, smaller boat that is intact. Keep in mind that, once you own it, you have the responsibility of disposing of it if it doesn't work out, and it could be costly to haul that rascal to a landfill. I wish I could be more encouraging.
