Mounting hardware on Boom - Page 2 - SailNet Community
 6Likes
post #11 of 21 Old 04-03-2014
TakeFive's Avatar
Re: Mounting hardware on Boom
The only time I tapped aluminum was to mount mast gates. In that application, the screws did not have much stress on them. But if they ever strip or corrode, I would need to re-drill in exactly the same place - I can't move the mast gate somewhere else. For that installation, I downsized the holes (and screws), so I could get a "second chance" to re-tap later with a larger hole/screw.
I use thread lock for the threads to minimize metal-to-metal contact, and also lay down a polyethylene sheet between the SS mast gate and the mast. So far, no corrosion - but I'm in a fresh water environment.
Rick S., Swarthmore, PA
TakeFive is offline
The Following User Says Thank You to TakeFive For This Useful Post:
BeejDeC (04-03-2014)
post #12 of 21 Old 04-03-2014
Over Hill Sailing Club
smurphny's Avatar
I attached some of my mast steps with 1/4" rivets. A gun like this:http://http://www.amazon.com/Astro-P...ref=pd_cp_hi_1 is needed for large rivets. A small pop rivet gun will be circular file material pretty quickly. As far as coating them, I'm not really sure it makes any difference but you can use any number of products. I usually use Penetrox if anything at all, mainly because I have it left over from electrical jobs. For threads, I always use a thread lock product like Loctite if I want it to stay put, never-seez:Bostik Marine Grade Products - Industrial Supply Group if I want it to later be removable. Never-Seez should be std. equip. on any boat:-)
smurphny is offline
The Following User Says Thank You to smurphny For This Useful Post:
post #13 of 21 Old 04-03-2014
Master Mariner
capta's Avatar
There are dozens of "tap and drill size" charts online.
I have never used the tef-gel, but I do use a neverseize product specifically made for alloy instead of steel. It works for years on ss in alloy (I do all my outboards with it and I never need heat or penetratants to work on them) and it's available at any auto parts store, usually gold instead of gray colored.
facebook.com/svskippingstone
Our Videos;
capta is online now
The Following User Says Thank You to capta For This Useful Post:
post #14 of 21 Old 04-03-2014
The threaded hole that secures my mast gate is the thing that causes me the most trouble. It seems to instantly seize and then strip the next time I need to remove the screw. I've re-tapped it several times and I'm now at the point where the next size up would bee to big, so I'm considering installing a threaded insert. So far though, I haven't found them in Stainless Steel. If anyone has ever seen them in stainless, I'd love to know the source.
Quickstep192 is offline
post #15 of 21 Old 04-04-2014
smurphny's Avatar
If you can't find s.s., maybe make your own. Cut off a fine thread bolt of a larger size, center punch it and drill/tap it back to the original size. You could also just weld it over and re-drill/tap. Spalling of s.s. threads is a PITA, one of the negative qualities of s.s. It seems as soon as the threads get even slightly deformed, they jam up and eventually strip out.
smurphny is offline
post #16 of 21 Old 04-04-2014
TakeFive's Avatar
They do make aluminum or nylon screws, but they are soft. Since this is not a high-stress application, an Al or nylon screw might have less corrosion - if you have room to try one more tap.
TakeFive is offline
post #17 of 21 Old 04-04-2014
If I understood this correctly, the OP is intending to put a turning block at the mast end of the boom so that he can lead the bitter end of the reefing line to the cockpit.
How you attach the block seems like a moot point to me. I wonder why one would want to lead the reefing line to the cockpit. You will be up at the mast securing the cringle on the gooseneck anyway (translation for lingo: securing the new lower corner of the reefed sail to the mast end of the boom), so why not leave the reefing line there. On a small boat, it saves valuable space in the cockpit which would otherwise be cluttered with another line end, and on a bigger boat it eliminates friction at multiple turning blocks needed to lead the line aft.
meteuz is offline
post #18 of 21 Old 04-04-2014
Originally Posted by AlaskaMC View Post
This seems to be logical to me in my situation. I have to add many things to my boom but it is on a small boom with far from 1/4'' thick alum. So, stainless rivets were my question. Seems like a much more secure solution. Do you do anything to isolate the SS from the Alum on the rivets?
I've had generally bad luck tapping aluminum. In time, the screws seem to always tear out the threads. Instead, I've been using SS rivets. I'd be curious for any thoughts on this.
If you use monel pop rivets instead of SS, you'd have no corrosion problems.
I believe (no expert here) the reason you'll not find SS threaded insert is due to the steel properties. SS is much harder than aluminium to form the lip that would secure the insert.
But since aluminium ones are available, its just a matter of coating the threads with Tef-Gel or similar. This way you have a secured screw that is protected from corrosion.
I totally agree. Leading lines to the cockpit may be misleading (pardon the punch) -- you may believe that its going to be easier, but since you have to go to the mast anyway, it may not be. Save the work until you have enough experience to determine the best approach.
SVTatia is offline
The Following User Says Thank You to SVTatia For This Useful Post:
BeejDeC (04-07-2014)
post #19 of 21 Old 04-04-2014
christian.hess's Avatar
Im a huge fan of hooks for the tack...simple and if maintained well it eliminates yet another line
those single reefing systems are anything but simple or effective....
all lines at the mast....on big boat best thing you can do is have those stainless pulpits or whatever they are called...love them for helping you keep in place, tying things and supprting you while near the mast...
dont like the whole lines led aft dealyos...think they do more harm than good especially on small boats where a step or 2 has you at the boom and mast ready for action...
oh the only thing I like having aft is a jib downhaul...not needed on many boats but I singlehanded a 26 footer a lot that had a nice jib downhaul that could be used in the cockpit...that way I could dock under main sail power alone most of the time
SVTatia likes this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
The Following User Says Thank You to christian.hess For This Useful Post:
post #20 of 21 Old 04-04-2014
ASA and PSIA Instructor
Originally Posted by BeejDeC View Post
...I'm putting a reefing line on my C&C 30. The boom has a block mounted in the appropriate spot just aft of the leech but I'll need to mount a turning block on the luff end to run the line to the base of the mast and into the cockpit..j
Congratulations on selecting a beautiful boat. I've always considered my fondly-remembered C&C 30 the best instance amongst my boat ownerships. Enjoy.
I expect the main halyard does not come back to the cockpit, and that there is no line led aft for the reefing tack. If you do not have both these in place, you need to go to the mast anyway to reef, so skip the idea of running the reef inf line aft, and just use the standard cleat installed forward on the boom to secure your reef. There should be two, one for each of the two standard reefs.
sailingfool is online now
The Following User Says Thank You to sailingfool For This Useful Post:
Tags
boom , hardware , hole , install , pilot
Mounting solar panel on top of dodger hardware? SanDiegoChip Gear & Maintenance 14 03-05-2010 11:24 AM
Solar Panel mounting hardware GreatWhite Gear & Maintenance 9 01-01-2010 09:03 AM
GPS mounting hardware wind_magic Gear & Maintenance 23 01-19-2008 08:59 PM
Mounting Plates for Deck Hardware kamcgough Gear & Maintenance 2 05-22-2003 11:56 AM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
