Painting the deck.... - SailNet Community
 1Likes
  • 1 Post By ABH3 Boyer
post #1 of 6 Old 04-07-2014 Thread Starter
Hello all, Amateur here looking for some solid advice....
The gelcoat on my grampian is old and hazy... Cracking and just all around worn n weathered. I can't afford to go crazy and repaint the entire boat hull & deck... Nor do i want to start the project and remove all the hardware attached to the deck....
Can i repaint the deck with foam rollers and tape off the deck hardware? What sort of prep would i have to do to make this a one weekender job? Will the paint peel if i just roll on a new coat of gelcoat? These are my questions, lets fish for answers....
PS - Bought the boat for 500 big ones, and intend on keeping her for at least another season. I just want to make her prettier on the outside!
Grampian1989 is offline
post #2 of 6 Old 04-07-2014
Bristol 45.5 - AiniA
Re: Painting the deck....
Yes, you can paint it. The more stuff you take off the better the finished job. If it is for one summer I would leave it as is. If it is worth doing, it is worth buying proper marine payment meant for deck use. These require more care than latex house paint but are not beyond a careful amateur's ability. I have used Signature Finish paint that you get direct from a guy in Florida who provides very detailed instructions and all the bits you want. Certainly this is not the only way to go. Check the websites for Interlux and other marine paints.
BTW, if you are going to paint no-skid you want to add a compound to the paint. These range from very coarse to finder. You add it to the first coat and put an extra coat of paint without grit on top.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #3 of 6 Old 04-08-2014
paulk's Avatar
You can prep and paint in a weekend, but the results will probably look like you did it in a weekend. To REALLY tape off the hardware and ports so no paint gets on them will probably take a whole morning or more (depending upon the size of the boat). Sanding and prep for schlock paint and really good 2-part polys are pretty similar and should probably take about a day. Less finnicky paints don't call for a solvent wash and have wider temperature/humidity windows, so you can slap them on pretty quickly. The problem is that less finnicky paints don't last as well, so you might expect to need to do it all over again in a season or two. We used 2-part polyurethane and had to wait for the temperature to warm up, the air to dry out, and the wind to stop blowing before we painted. It took weeks. The paint has held up about 10 years, however. If you don't want to have to do it again soon, do it right the first time. More recently we have had reasonably good results from Interdeck nonskid paint - but it hasn't been on for ten years yet.
paulk is offline
post #4 of 6 Old 04-08-2014
Try just a really good cleaning. The deck may not look so bad when clean in full sun.
I paint my deck with a one part urethane every two to three years. Most one part paints will last a few years if the surface is well prepared and manufacturer recommended primer used.
One day to clean and prep, one day for primer one day for finish paint.
Year two or three, clean and finish paint one day, I have never had paint peel off, wear away yes but not peel off.
This will not be as good a finish as a two part coating, but not bad for a $500 boat.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
The Following User Says Thank You to Ulladh For This Useful Post:
Smier (04-09-2014)
post #5 of 6 Old 04-08-2014
Marine grade gorilla grip non-skid worked very well for me. Everything that I wasn't replacing got taped off. Wipe the clean surface down with a solvent like MEK and roll it on. It looks beautiful and comes in every color under the rainbow. Made my 1977 boat look like new. Also is holding up better than anything I have ever used.
christian.hess likes this.
ABH3 Boyer is offline
post #6 of 6 Old 04-08-2014
Barquito
Barquito's Avatar
Would be difficult to prep the deck, and tape all the hardware in one weekend. Let alone, painting multiple coats. Also, if you haven't checked the price of marine paint you may be shocked. OTOH, I am going to paint my $500 boat soon, b/c I don't want it to look like sh!t, or at least I want it to look like a different color sh!t.
Valiant 32
Barquito is offline
Tags
deck , gel coat , paint
options for painting my deck eggman2001 Gear & Maintenance 14 11-01-2012 09:30 PM
Deck Painting SanSimon SailNet FAQ 2 10-16-2011 10:21 PM
Deck Painting Help! Duncan1650 Gear & Maintenance 7 08-02-2009 03:17 PM
Painting the Deck tager Gear & Maintenance 26 04-22-2009 02:30 PM
Painting Hull, Deck, and Nonskid Sue & Larry Her Sailnet Articles 0 10-14-2001 08:00 PM
