Main anchor question. - SailNet Community
 3Likes
post #1 of 22 Old 04-16-2014 Thread Starter
Censored4 your protection
Cope44's Avatar
I have two anchors on my boat. Both seem to weigh @20LBs and are the same style.
The one I use as my "main" has 190' of 3/8" polly line and 53' 10MM light chain.
My stern anchor has 120' of 7MM polly line followed by 30' of heavy 3/8" chain.
My question is should I switch the heavy line to the heavy chain or do you think the extra 23' of chain makes up for its light size?
Thanks for the time and advice.
CM 21 #291
I fight to refuse a battle of wits against a one armed man.
Cope44 is offline
post #2 of 22 Old 04-16-2014
Bristol 45.5 - AiniA
Re: Main anchor question.
Not sure about your description of the change since 3/8" is basically the same as 10 mm. The chain is more than enough for a boat and anchor of that size. I have 3/8" chain on a 40,000 pound boat. The poly line is not at all strong, that would be the first thing to replace I think. Is the anchor on the right a genuine Danforth (it should be stamped on the shaft)? If so, it will be a much better anchor than the other one. I would use the right-hand anchor, either chain and a new piece of nylon, 3-strand. How deep is the water where you anchor? that could help with your choice. Allow 7 to 1 scope, based on the depth of the water, the height of your bow, and any tidal increase that might happen. So if the water is 20' and the tide is 5' - you are working with 20 + 5 = 5 = 30 feet times 7. You would want roughly 210 length of anchor rode.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is online now
post #3 of 22 Old 04-16-2014 Thread Starter
Cope44's Avatar
Dont know why I put 10mm the small chain is 1/4"
I only sail on a lake so no tide. I normaly anchor in 15-20 feet of water with soft sand and a few large rocks.
I would like to anchor out overnight and want to make shure I get the best set incase the winds come up at nght.
Thanks again.
CM 21 #291
Cope44 is offline
post #4 of 22 Old 04-16-2014
jackdale's Avatar
To be honest, I would use neither set-up.
Danforths will trip in a wind shift. The one on the left is especially bad for that.
Poly chafes quite badly. Anchor rode should be nylon to give some stretch and shock absorbency.
I have used Danforths as secondary anchors in conditions which are not subject to wund shifts, but never as a primary.
Poly chafes quite badly. It also floats - not good.
jackdale is offline
post #5 of 22 Old 04-16-2014
The heavy chain is a poor match to the anchors, but as long as you have it you might as well use it. If you want a more secure hold, heavier chain is better.
You don't have an anchor rode. That yellow poly rope will work great to mark out a swimming area, but it's not an anchor rode. Get some nylon rode.
GTJ
SailingJackson is offline
post #6 of 22 Old 04-16-2014 Thread Starter
Cope44's Avatar
so the heavier shorter chain should hold better than the much longer much lighter chain?
What makes the anchor on the left worse than the one on the right? The left one seems just a tad heavier.
Thanks again for the time and advice.
CM 21 #291
Cope44 is offline
post #7 of 22 Old 04-16-2014
Your 30' of heavy chain should be about 53 lbs. Your 53' of light chain is probably 38 lbs. URL reference is here: New Page 1
How heavy is your boat?
GTJ
post #8 of 22 Old 04-16-2014
With the anchor on the left [edit, oops], if the wind switches in the middle of the night the boat will 'sail' over the anchor making the shackle slide up the slot to the other end. The boat pulling will then pull the anchor out of the mud. It may or may not reset itself. With the other anchor, the pull stays at the end of the shank so when the wind shifts you will have a chance that the anchor stays in the mud and just pivots to the new direction.
There are lots of anchor designs out there, some of which are much better than either of these but they are not cheap and you have these two. I would go with the anchor on the right, the 3/8" chain which is sort of overkill for the size of anchor and boat, but that is not a bad thing. Invest in 200' feet of 1/2" (or even 7/16") nylon rode with a loop spliced in the end where it connects to the chain. You want a 'thimble' (doesn't look anything like a sewing thimble) inside the loop for chafe protection. Make sure the anchor shackles are sound and after you tighten the shackle pins lock them either with wire ties or stainless wire (better) methods. With either you go through the hole in the shackle pin and around some part of the bow of the shackle.
jackdale likes this.
post #9 of 22 Old 04-16-2014
jackdale's Avatar
In a wind shift, the slot in the shank will allow the shackle and chain to slide down the shank and dislodge the anchor from the bottom.
jackdale is offline
post #10 of 22 Old 04-16-2014
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Thanks again.
put down both in a Bahamas setup
Bill-Rangatira is offline
German main sheet question NewportNewbie General Discussion (sailing related) 12 05-28-2012 10:33 PM
question on Rhodes 22 furling main adam333 General Discussion (sailing related) 10 04-12-2011 09:50 AM
Yet another anchor question. Has anyone seen/used an Oceane anchor? SVDistantStar Gear & Maintenance 2 08-28-2008 01:09 AM
Hood Stowaway main question killarney_sailor Gear & Maintenance 1 06-17-2008 10:27 AM
Jib or Main question? nk235 General Discussion (sailing related) 27 05-29-2008 12:38 AM
