ATN Tacker experiences??? - SailNet Community
 2Likes
post #1 of 13 Old 04-18-2014 Thread Starter
NewportNewbie's Avatar
I have been wanting to get an Asymmetrical Spinnaker so I can go Pole-less. I have a standard Spinnaker that came with the boat that has never been used. I saw that the ATN Tacker attaches the clew to the furled headsail and lets you fly it like a Assy Spinnaker. Seems like a cool way to use the Symmetrical Spinnaker without the pole....
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 13 Old 04-18-2014
jimrafford's Avatar
Re: ATN Tacker experiences???
I have one. Waste of money. It now is used to hang my hammock. Just run a line from the tack of the chute thru the anchor roller back to a cleat.
Jim
SloopJonB likes this.
S/V Deja Vu
CS 40
jimrafford is offline
post #3 of 13 Old 04-18-2014
Minnesail's Avatar
I have extensive experience with an ATN Tacker, in that I once helped someone take one out of the package. We rigged it and flew the asymmetrical while tied up to a dock in a 1-2 knot breeze. We tacked it once, then took it down.
Worked great in those conditions.
Catalina 22
on a starboard tack
Minnesail is offline
post #4 of 13 Old 04-18-2014
Senior Moment Member
SloopJonB's Avatar
Jim
Done a fair bit of that on a Hunter 38 - works quite well. When you know what height works for the tack, you can make up a strop instead of using a running line back to the cockpit. We got lucky and started with a strop I had on hand and it turned out to be the perfect length.
You don't want the tack to fly too high or the chute will roll back too far. That is supposedly the benefit of the Tacker - it holds the tack on the headstay.
You can accomplish the same thing with a piece of rigging wire and some parrel beads if you want to get the tack up high off the deck.
SloopJonB is offline
post #5 of 13 Old 04-18-2014
ATN Snuffer with an Asymmetrical spinnaker was one of my best sailing investments. Greatly increased foresail sail area to enhance sailing in light wind. Of course, down wind sailing ability is enhanced, but I was impressed with the sails ability to close haul.
Snuffing and unsnuffing is a breeze.
Alive3and3Well is offline
post #6 of 13 Old 04-18-2014
jackdale's Avatar
I have used ATN Tackers on several boats. They are somewhat misnamed - they should be called gybers.
I have used them from a close reach to a dead run. They provide some control over the tack of a gennaker. They allow for a tighter close reach and provide for more stability on a run. (I actually prefer to broad reach and gybe.) On a close reach harden uo the luff by bringing the tack down. On a broad reach ease the tacker and fly the gennaker just as you would a spinnaker by watching the shoulder.
I have use the fabric versions, but I find that they do not slide along the furled genoa as well.
When I started flying gennakers we had hank-on foresails sails. We used a hank on the tack to slide slide on the forestay.
DDW
Close reach (fabric tacker)
jackdale is offline
post #7 of 13 Old 04-18-2014
MikeOReilly's Avatar
This is exactly our setup. Lets me set the tack hight and adjust the luff tension on our genniker. I looked at the ATN tacker, but thought the bead arrangement would be better. Don't know b/c I've never used the tacker. The beads are certainly a lot cheaper
Why go fast, when you can go slow.
MikeOReilly is offline
post #8 of 13 Old 04-18-2014
no longer reading SailNet
Alex W's Avatar
I had trouble with beads catching on the jib sheets as you raise and lower the tack. I gave up on them and went back to just flying it off of the tack line. If I'm flying the asym deep I just put it on the pole like a symmetric spinnaker, that works a lot better than the beads or tacker and isn't much work.
Alex W is offline
post #9 of 13 Old 04-18-2014
I'm on the side of the positive reviews here. I had one on my 25' boat and now use one on my 36' boat. It was nice sometimes on the 25', it's essential on the 36' boat. The bigger the boat is, the more important it is. My sail is 1000 sq ft and it really helps to manage it. A couple of points here:
  1. Only really important down wind. It doesn't matter if you're higher than a broad reach. Beam reach and it's pointless. Helps when you want to let out the tack and let the sail run high.
  2. Run a safety line. With all the confusion and commotion of taking down a sail when the wind gets too strong it's easy to have the thing go overboard.
GTJ
SailingJackson is offline
post #10 of 13 Old 04-19-2014
Yorksailor's Avatar
In Jack's second picture, even though he is in very light winds, the roller furling foil is already bending. If the wind suddenly piped up to 20+ knots I think the foil would be damaged.
Because of this I have stopped using mine and gone back to a tack line off a block on the bow roller.
christian.hess likes this.
Yorksailor is offline
ATN Tacker mandolinwind Gear & Maintenance 5 11-24-2006 08:34 AM
ATN Tacker MPollock General Discussion (sailing related) 2 03-10-2006 06:01 PM
Tacker for my Gennacker megsmom General Discussion (sailing related) 1 02-07-2005 03:39 PM
An assymetrical spinaker tacker megsmom Gear & Maintenance 0 02-05-2005 01:13 PM
tacker or related gear jipper74 Gear & Maintenance 2 10-18-2002 03:01 PM
