Blogs
User Name
Old 05-18-2001
schoonerman schoonerman is offline
schoonerman is on a distinguished road
captain''''s license
I''m planning to get a 6-pack license this year and am interested in hearing from licensed skippers as to the best way to go about it (best study guide? take Sea School course?, etc.). Any advice will be appreciated.
Old 05-18-2001
gershel gershel is offline
gershel is on a distinguished road
Taking a course was the best way for me. Also some schools are authorized to give the test. If you have the required days,go for the masters rating, or the highest rating you can. The 6 pack is a waste, after going through all that studying.The tests are virtually the same.Also get a sail rating attached to your liscence
Marc
Old 05-22-2001
CaptBobMcc CaptBobMcc is offline
CaptBobMcc is on a distinguished road
schoonerman:
gerschel is correct, go for your master''s license. It will include the so-called "six''pack".
Be sure to get the sail endorsement on your license. Might as well go all the way and get power and steam, too. Try to get at least a 100 ton rating and near coastal routes as well as inland. You''ll enjoy it more with the higher grade license.
Old 05-23-2001
wizardscocoon wizardscocoon is offline
wizardscocoon is on a distinguished road
How do you go about getting the required sea time, while holding down another not water related job? Can time spent on your own boat count if it''s just yourself or yourself and family?
Old 05-23-2001
Yes, time aboard your own boat counts. If you''ve been sailing for a long time, those days and weekends accumulated will add up.
Old 05-24-2001
Denr Denr is offline
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
The basic licence you refer to "six pack" no longer is available from the USCG. It is now called OUPV which stands for operator of un-inspected private vessel. Go for the masters, it is only one more module on the test. You will need to document your sea service on your application. The service time can be from the operation of your own vessel; one does not have to have a job "on the water". I hope you kept an accurate log; it makes the application process much easier.
Old 05-24-2001
noctaluca noctaluca is offline
noctaluca is on a distinguished road
I agree with the above. Just a bit more info. A "sea service day" is defined as a minimum of four hours in which the boat leaves the dock. An example could be as follows, One hour at the dock to prepare to sail, two hours of sailing away from dock, and one hour to putting the boat to bed at the dock. Those short evening sails can sure add up fast.
I have a 500 ton near coastal license. I went to a school for my 100 ton. Then after 1800 days of captaining a 100 ton boat I qualified to upgrade to the 500 ton. I did not go to school for this license, but I did order a home study guide. I found this most useful and very thorough. It was pricey, about $800 for all materials, but considering it is my livelihood it was well worth it. The company is Houstin Marine. They are easy to find on the web and have lots of info on what you may need. I recommend them.
Good luck.
Bill Robbins
Old 05-24-2001
kimberlite kimberlite is offline
kimberlite is on a distinguished road
houstin marine?--- i couldn''t find it
eric
Old 05-24-2001
Try this web address: It worked for me.
http://www.houstonmarine.com/
Good luck
Bill
Old 06-05-2001
clearskys clearskys is offline
clearskys is on a distinguished road
What if you cannot find your log/journal of your hours after working 12yrs. on charter boats. Also, does the Capt. you worked with have to authenticate that you did those hours?
CC
Display Modes
vB code is On
looking for Captains Ring TC2 General Discussion (sailing related) 2 07-13-2006 11:04 PM
Mom''s Captain''s license bubb2 General Discussion (sailing related) 0 11-05-2004 03:44 PM
license value?? lizardie Learning to Sail 7 02-17-2003 01:42 PM
Delivery Captains Available CaptainJenkins General Discussion (sailing related) 0 09-23-2002 10:32 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
