Smallest planing dingy/motor - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Old 04-22-2014
asdf38's Avatar
asdf38 is on a distinguished road
I have contradictory goals for a tender
1) Suitable for towing and/or storing from/in my 26'
2) Capable of being carried/wheeled ~750' by myself
3) Suitable for an ~8 mile passage (from my house to my boat).
So basically, like I said, I want the absolute smallest boat/motor combination capable of planing (with one person).
So I wanted to know people's experiences with small motors and small boats with decent planing performance.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 04-22-2014
hpeer is on a distinguished road
Re: Smallest planing dingy/motor
PERFORMANCE….This is where Porta-Bote really excels over ordinary rigid craft and inflatables. Imagine being able to get up on a “plane” using a tiny 2.5hp outboard. You can when one person is in the boat and at the helm. Porta-Bote takes a standard “short shaft” engine. Do you know what kind of power it takes to get an equivalent sized aluminum or fiberglass boat up on a plane? You would have to invest in a high priced, exceedingly heavy engine that weighs as much as the hull!! And remember, you have to lift this cast iron monster over the transom to get it installed.
Porta Bote | Porta Bote | Hi Performance
They sell a wheel kit to roll it.
  #3
Old 04-22-2014
jeffzee is on a distinguished road
i have a walker bay 270 air floor with a 6hp suzuki, great combo. the walker bay is only 55lbs! it being light was the reason i purchased it as i wanted something i could tow behind my san juan 7.7 without being slowed down. It planes well with the 6, an 8 would be even better!
  #4
Old 04-23-2014
Ilenart's Avatar
Ilenart is on a distinguished road
I have a Aquapro SLR710 inflatable dinghy which has an Alum hull. The dinghy is 7 ft 10" / 2.4m long weighs 26kg / 57lbs and I have a Mercury 3.3HP outboard. With just me in the boat and so long as I sit in the middle seat the dinghy planes, probably 10-12 knots, though I have never measured it. I weigh around 70kg / 150 lbs and even one of my kids onboard is enough to stop the dinghy planning. Note that the 3.3HP has a pretty small integrated tank. For a 8mile trip you probably want a separate fuel tank, which you can place forward to help balance the dinghy.
I think the reason this dinghy planes so well is due to the aluminium hull.
Ilenart
  #5
Old 04-23-2014
lancelot9898 is on a distinguished road
Not too long ago I sold my 25 year old Archilles inflatable and motor. The dinghy weighed in at around 100 lbs and had a hardwood floor and I think it was 9 feet long. The Nissan 5hp 2 cycle would plane with myself at 200lbs and wife at 120lbs. With that hardwood floor it was difficult to assemble on deck and I now need something smaller. With a smaller and lighter dinghy I could probably get by with a smaller outboard and still plane. I did experiment around with different props, but can't remember what pitch I ended up with.
  #6
Old 04-23-2014
ReefMagnet's Avatar
Living the dream
ReefMagnet is on a distinguished road
Planing depends on the load and length of the dinghy. The shorter the dinghy, the harder it is to get up on the plane. My 9 ft fibreglass hull rib will plane with just my 100 kg weight and a 3.3 hp outboard (I have to sit in the middle as well). With the wife onboard as well (weight unknown ) and her luggage the same dinghy won't plane with our 9.8 hp o/b. We once had a 12 ft inflatable dinghy with an 8 hp o/b and it would - just - get on the plane with the same load.
Sent from my GT-P1000 using Tapatalk 2
  #7
Old 04-23-2014
Multihullgirl is on a distinguished road
TAKACAT Lite T300L with 8hp engine, although if you want to keep it really light, the 2hp will push the dink just fine, but it won't plane
  #8
Old 04-23-2014
MikeGuyver
MikeGuyver is on a distinguished road
West Marine AL290 (9'10") w/ older 8 hp Honda. I weigh in at a semi-chubby 220. On a plane the Garmin said 21kts. With wifey aboard it has trouble climbing the bow wave, but will plane at 15kts.
  #9
Old 04-23-2014
asdf38's Avatar
Thanks for the posts.
Ilenart
This is a good datapoint. I currently have a merc 3.3hp and I really don't want to go larger. At ~28lbs it's quite a jump to any larger (or newer) motors.
But it sounds like I have at least some hope with smallish inflatable, although a rigid floor adds cost.
Porta-bote:
I'm well aware of porta bote and I find it pretty intriguing. However I havn't answered to my satisfaction whether the 8' will plane well with the 3.3hp. I'm actually staring at an 8' for sale right now in the neighboring town, and that fact is partly what drove to start this thread - I wanted to see what other possibilities are out there.
While I like the porta-bote it certainly has pros and cons. My biggest concern is that it's a bit less suited for towing. An inflatable is more forgiving in that it can flip, bounce off the mothership etc without any real consequences. And while the porta bote could be stowed on my 26, the seats and transom apparently take up quite a bit of space, on top of the windage the hull would add if tied to my lifelines.
It's all a lot of compromises.
If any one else has any more testimonials for boat/motor combinations that would be great.
  #10
Old 04-23-2014
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
Why not strap the poratbote down flat, rather than against the lifelines? Strap it to the transom, or next to the mast. Also, why not ask the owner if you can take it for a ride with your engine (or his/her's, if they have one)? That will give you a sense for how it performs. If you take the boat out with your engine, offer to leave a security deposit.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
You may post attachments
You may edit your posts
smallest dinghy for use with 9.9hp motor Incantation General Discussion (sailing related) 6 11-15-2010 06:51 PM
electric motor for dingy saurav16 Gear & Maintenance 4 07-11-2007 02:46 PM
Dingy Outboard Motor rclampitt Cruising & Liveaboard Forum 9 02-22-2003 02:14 PM
Dingy Outboard Motor rclampitt Gear & Maintenance 6 01-21-2003 02:55 PM
Dingy Outboard Motor rclampitt Cruising & Liveaboard Forum 0 01-10-2003 06:38 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
