A Ketch into a Cutter...or not - SailNet Community
 1Likes
  • 1 Post By mad_machine
post #1 of 9 Old 04-27-2014 Thread Starter
I'd rather be sailing....
afrinus's Avatar
The Admiral is not scoffing anymore anytime I'm talking about "upgrading", even starting to join in looking at options....
I've always been partial to the Bayfields or Cabo Rico's, but as it happens, the ones I can afford are all ketch rigged.
Looking at the amount of rigging on a ketch and considering we will mostly sail shorthanded, what are the options to remove the Mizzen, turning the boat into a Cutter? (it looks like one can get lost between all the riging....)
How will this affect handling? Cause major weather-helm issues?
Any mods needed to the main? Maybe extending the boom?
Or, am I looking at this wrong, does the ketch provide better options with the various sail configurations and should I not mess with a good thing...
"Boat-less no more...
afrinus is offline
post #2 of 9 Old 04-27-2014
Re: A Ketch into a Cutter...or not
Why mess with a good thing? It will change the balance and you may even have to shift the mast, or at least extend the main. The ketch sails are easy to balance and handle.
chris_gee is offline
post #3 of 9 Old 04-27-2014
Wingnut
Personally, i like sailing a ketch rig, especially when short/single handed. Lots of options and very managable sails.
In my opinion its best to consider the mizzen a steering/balance sail than a driving sail.
Sent from my HUAWEI Y300-0151 using Tapatalk
Dirtyfloats is offline
post #4 of 9 Old 04-27-2014
If you aren't looking forward to the complexity, cost, and maintenance of a second mast, boom, etc., then you might want to look harder at the cutters that are already out there.
I totally LOVE my furler staysail!
Mycroft is offline
post #5 of 9 Old 04-27-2014
okawbow's Avatar
I'd rather handle the mizzen from the cockpit, than have to go up and deal with the staysail in rough weather. With a ketch rig; a short handed crew can sail jib and mizzen anytime the wind picks up. As others have said; the ketch balances nicely. You might lose a few degrees of pointing into the wind, but the ease of sail handling and variety of sail plan makes the ketch a winner for cruising.
Chuck
Privateer 26 Schooner
okawbow is offline
post #6 of 9 Old 04-27-2014
christian.hess's Avatar
youd be eliminating one of the many benefits of a ketch rig
better sail sizes for sailing shorthanded, being smaller for a given boat size they are easier
sail configuration options
in heavy weather you can drop the main and have a mizzen and jib setup that will be perfectly balanced
using a reefed mizzen in rolly angorages as a riding sail
etc etc etc etc etc
I loved sailing my ketch
I also in really heavy downwind sailing loved dropiing the jib and mizzen and simply run the main...being twin stayed aft and heavily supported I could sail like this in very heavy winds and quite comfortably
on my old h28 ketch I did my best run of around 175 miles in a day this way
my fastest speed on the boat was this way too around 13 knots full main up blasting down rollers in 35 knots...it was a thrill ride! completely awesome to be in!
anywhoo
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #7 of 9 Old 04-27-2014
forgot to mention the biggest issue with eliminating ketch or twin mast rigs(some yawls can be mande into sloops or cutters easily)
for example a pearson triton
is MAST placement
it will be too far forward on 99 percent of ketches if you eliminate the mizzen...
post #8 of 9 Old 04-27-2014
Old enough to know better
To do it right would involve moving the mast back, as a cutter is more than just a sloop with two for sails. Even on a deck stepped mast that is not going to be easy. Most ketches will have the mast quite forward. Also may need to replace the mast to get enough sail area, depending on the boat. Better to live with it, and learn to use it to your advantage. Depending on the rig you might be able to convert to a Sloop by adding a new longer boom.
miatapaul is offline
post #9 of 9 Old 04-27-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
A ketch may look extremely complex to somebody who has never sailed one.. but they are your friend for sailing short handed. All the answers above are very rue.
christian.hess likes this.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
Ketch vs. Cutter Dking59 Boat Review and Purchase Forum 19 07-10-2016 03:50 AM
What's a cutter rigged ketch? And a slutter? kwaltersmi General Discussion (sailing related) 29 03-08-2014 02:11 PM
Please Advise on This Hardin 45' cutter ketch Winderlust Boat Review and Purchase Forum 48 03-03-2014 08:19 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 03:47 PM
Gulfstar 44 Cutter Ketch Ron D General Discussion (sailing related) 2 04-10-2006 01:34 AM
