Considering a foam luff on a 150 LP cruising sail - SailNet Community
 3Likes
post #1 of 13 Old 05-01-2014 Thread Starter
I have the impression that about half of the cruising sailors prefer foam luffs and I'm interested in knowing what some of you are currently using or purchasing.
While we are not shy about driving the boat pretty hard, I'll probably be reefing more than I would 30 years ago....
Currently thinking about getting a new 150 for our Ericson 27.
Any thoughts?
Joe
Reviving an Ericson 27...
Joe S is offline
post #2 of 13 Old 05-01-2014
ASA and PSIA Instructor
Re: Considering a foam luff on a 150 LP cruising sail
I'd suggest adding a foam luff on your primary use sail, on my boat its a %135. The 100% I am planning to purchase will not have such a luff, and if I ever get to a 150% with this boat, that would not either. Both the 100% and 150% are in effect special use sails, put up when conditions call for them ( for the $150 that would be racing...). You sail choices would of course reflect local conditions.
The luff flattening provides some minor reduction in the sail shape degradation that starts with one or two turns on the furling.
MedSailor likes this.
sailingfool is offline
post #3 of 13 Old 05-01-2014
no longer reading SailNet
Alex W's Avatar
On a 27' boat I'd rather have hank-on sails and a good sail inventory (most of which could be purchased used for pennies on the dollar).
I agree with sailing fool, a 150% sail is a special purpose light wind sail and should be made of light fabric. A foam luff would be a waste because it couldn't handle higher winds anyway.
I have a 135% with a foam luff and it rolls up better than the previous 135% did that didn't have a foam luff. It still doesn't roll up all that well, and my 105% working jib lets me point higher and the boat perform better than the 135% sail does rolled up the same amount.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
oysterman23 (05-01-2014)
post #4 of 13 Old 05-01-2014
Closet Powerboater
MedSailor's Avatar
Agreed. Also, the 150 will want to be flown in very light winds, and the foam luff and sumbrella cover (in case you're thinking of adding one of these) add so much weight that it will hang limply in light air.
Personally, I feel that there is a point in the LP where additional size works against you. I knew a guy with a 170% sail, and the sail itself was so heavy, it took more air to fly it than his 140%.
Also, taking a 150% is going to be a PITA....
MedSailor
MedSailor is offline
post #5 of 13 Old 05-01-2014
Bristol 45.5 - AiniA
Interesting now, that foam luffs are not made of foam anymore. They seems to use a row of parallel lines instead.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #6 of 13 Old 05-01-2014
Alex W's Avatar
That is what my foam luff sail has. The lines are still foamy. They just help to roll up the center of the luff tighter than the edges so that the sail has less belly when rolled.
I think the newer style ones (with multiple stripes) are a higher density foam than the older ones, so it doesn't squash as flat and wear out as quickly. That is what it feels like anyway comparing a newer and older foam luff sail.
Good furlers also have an independent tack swivel that allows the center of the sail to be rolled before the head and tack. Having that and the foam luff does help. It still doesn't allow you to point as high as a smaller sail, because the partially rolled sail still has this big sausage at the leading edge and greatly reduces sail lift.
Alex W is offline
post #7 of 13 Old 05-01-2014
Foam seems to be a recipe for mildew, North has been using a lightweight, non-absorbent rope instead for quite awhile, now... At least, that's what my genoa has...
I agree that a 150 is probably gonna be wasted for this purpose, I think you reach a point of diminishing returns beyond a 125-130%, in general... Also, I'd suggest a UV material other than Sunbrella, it's quite heavy, and is quite susceptible to chafe. Not exactly sure what mine is called, it's some form of treated Dacron, it's held up well and holds to the shape of the sail better than many Sunbrella covers I've seen...
JonEisberg is offline
post #8 of 13 Old 05-02-2014 Thread Starter
I am going with the Sunbrella to avoid changing Dacron uv panels. I understand that there's a weight issue...
There's a lot of light air on Long Island Sound so I hesitate to go too much smaller but now I'm thinking about the fact that my old genoa is a pita to tack. Maybe a 140 would be a reasonable compromise.
Joe S is offline
post #9 of 13 Old 05-02-2014
BarryL's Avatar
Hey,
I agree that a 140 with a foam luff is a real good choice. That's what I have on my O'day and I'm very happy with it. I do put up the 100 in late fall and early spring but the rest of the year the 140 is on the furler.
The sailmaker should put a mark on the sail so you can see when it's rolled up to a 110 or so. The foam won't work miracles but you get decent shape from 140 to 110 or so.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #10 of 13 Old 05-02-2014
Alex W's Avatar
The 150% isn't a bad idea if you have a light air venue. I just think that trying to make a roller reefing sail with a UV cover, foam luff, and heavier cloth that can handle being a 120% sail is a mistake. Make two sails, a light weight roller furling 150% for light air days, and a general purpose 120-135% for all around use.
bristol299bob likes this.
Alex W is offline
Luff in the luff of main sail eggman2001 Learning to Sail 9 08-16-2012 01:12 PM
Loose luff on main sail questions MarkSF Seamanship & Navigation 16 05-08-2011 09:35 PM
Luff rope, or sail slugs? 75R20 Gear & Maintenance 4 06-22-2008 04:04 PM
Foam Luff Headsail Storage KeelHaulin Gear & Maintenance 1 04-08-2007 10:27 AM
Sail..changing from hank on to luff tape gentlerain Gear & Maintenance 1 08-21-2002 02:40 PM
