pics of sail covers made for lazy jack systems? - Page 3 - SailNet Community
 24Likes
post #21 of 65 Old 05-04-2014
Re: pics of sail covers made for lazy jack systems?
What is your E dimension? I have a nearly new UK Lazy Cradle for sale cheap if you are interested.
luv4sailin is offline
post #22 of 65 Old 05-06-2014 Thread Starter
christian.hess's Avatar
thanks luv4sailin
I just installed my main and covered it up temporarily with a cheap tarp
these are my measurements:
e is around 50inches
a or verticak height at mast is 44
l or the neck on top 17
b or overall length under boom is 178 inches
j or end of boom height is 12
the main is actually quite skinny and a bit short for the boom
btw the lazy jacks work great and I dont see any issues somply using a standard straight cover
honestly getting the slits at exactly the right spot might take some tweaking and Im in a hurry
well see what I get quoted for a simple cover down here
thanks
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #23 of 65 Old 05-06-2014
By E I mean the length of the boom. Mine is 12 feet and my UK sail cover system is built for a boom of that length or near it. I know most folks like the Stack Pack (Doyle) or Lazy Cradle (UK) systems, but I prefer to remove the cover from the boom completely when sailing, so I'm just getting a traditional sail cover again like I had for years.
jackdale likes this.
post #24 of 65 Old 05-06-2014 Thread Starter
jaja I was going by a cover diagram by mauri sail covers that showed e as the diagonal dimension of the flaked sail
anywhoo
the mast is just over 13 ft. long
thanks
post #25 of 65 Old 05-06-2014
Kynntana (Freedom 38)
gamayun's Avatar
My sail cover has slits and velcro where the lazy jacks tie under the boom. I keep the lazy jacks loose and use my main halyard as a back stay to jack up the boom when I'm in my slip. (I can explain this reasoning, if you like.)
It sounds like you're well on your way to getting this done, but if you want pictures of my setup, I could do that this weekend.
christian.hess likes this.
gamayun is online now
post #26 of 65 Old 05-07-2014 Thread Starter
no please do...all I have done is take measurements and installed a temporary cover
I just want to keep this simple and low budget...
the lazy jack systems works just fine really...I dont think it will bother me much...
anybody else with pics would be greatly appreciated, even if its just your homemade covers...
thanks
ps I have a nice topping lift so the boom is always taught, honestly I love topping lifts and think all boats should come with them
post #27 of 65 Old 05-07-2014
gamayun's Avatar
I'd be happy to provide pics. Stand by...
My main is free-standing so there's no topping lift, but I run the main halyard back to the boom for this purpose and it works great. I've been told that the lazy jacks shouldn't hold the weight of the boom all the time, and I see places where the lazy jack lines have scored the boom and mast, so it must be good advice.
post #28 of 65 Old 05-07-2014 Thread Starter
sounds great...yeah the lazy jacks are only holding the flaked sail
I can see where people would use them as a topping lift and that is a big no no
thanks guys!
christian
post #29 of 65 Old 05-07-2014
Minnesail's Avatar
Really? Bummer.
I'm installing lazy jacks on my little boat this weekend and the kit explicitly says they can be used to hold the boom up.
Currently the boat uses a little short bit (pig tail?) across the split backstays to support the boom. I was hoping to get rid of that.
Catalina 22
on a starboard tack
Minnesail is offline
post #30 of 65 Old 05-07-2014
gamayun's Avatar
Originally Posted by Minnesail View Post
Really? Bummer.
Why do you want to get rid of the pig tail? Does it catch when you're sailing? There're ways to fix this. Personally, I would get the lazy jack system for ease of dropping or reefing the sails, and then use the pig tail to get the weight off the system when you're in the slip. I think chafing happens when there's a lot of wind on the boom at slip and the lazy jack lines are too tight against the boom and mast. At least the way mine are set up, they are rubbing through the coating.
The Following User Says Thank You to gamayun For This Useful Post:
Minnesail (05-07-2014)
lazy Jack question jhgreen Gear & Maintenance 17 10-11-2013 07:19 PM
Lazy Jack 32 Bardo Boat Review and Purchase Forum 2 01-11-2009 08:28 PM
Home Made Lazy Jack System teddius Gear & Maintenance 27 07-16-2008 04:13 PM
Lazy Jack thoughts bostonpilot Gear & Maintenance 14 04-04-2008 02:51 PM
Lazy Jack - how to use? cyrusallen Learning to Sail 4 09-24-2002 04:42 PM
