Jib Sheet Diameter - SailNet Community
 7Likes
post #1 of 13 Old 05-15-2014 Thread Starter
Dave_E's Avatar
Jib Sheet Diameter
Hi All,
I'm fix'n to purchase a new one piece sheet for my 150 when I get it back from the sail loft. The sheet's that came with the boat are all 5/8" diameter (or real close to that). I never measured them before, but from what I can recall, the jib sheets were always larger diameter than anything else on the boat.
What diameter is yours?
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 13 Old 05-15-2014
davidpm's Avatar
Re: Jib Sheet Diameter
I just bought new jib sheets for my friends almond 31.
Got something like 95' and did a simple hitch in the middle.
We got 7/16" just because the 3/8 felt a little small for the hand.
He has non-self tailing winches so it doesn't matter.
5/8" is massive.
christian.hess likes this.
davidpm is offline
post #3 of 13 Old 05-16-2014
Assuming you have normal size winches on your boat they should have a SWL of around 1500lbs. You can use any size sheet you want, but there isn't much point in using massive line that will destroy all the deck hardware on the boat long before it is even noticeably stressed.
Greg
Stumble is offline
post #4 of 13 Old 05-16-2014
Superior Sailor
Squidd's Avatar
7/16" on sheets and main, 3/8" on halyards
Down sized from 5/8" and 1/2" cause it fits the winchs, cleats and guides better
vega1860 and christian.hess like this.
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #5 of 13 Old 05-16-2014
I've got 7/16" on 150 jib and 3/8 main sheet on my 23. 7/16" is comfortable and you only do 2 or 3 wraps on the winch anyhow. fits the cleats well enough. Be sure to use StaySet and not X. Just my humble opinion.
RickBoat is offline
post #6 of 13 Old 05-16-2014
no longer reading SailNet
Alex W's Avatar
My boat has a 20% smaller genoa than yours (300sqft vs 365sqft). I've used 3/8" and 7/16" jib sheets and prefer the latter. My jib sheets are 7/16" that taper down to 1/4" dyneema and attach to the clew using soft shackles. That makes sail changes a lot easier because I can use the same sheets for any of my headsails and don't need to re-run sheets when changing headsails. It is also a lot easier to flake sails when you don't have to worry about attached sheets.
Fisheries Supply has Samson line on sale for a good price for a few more days, right now is the time to buy if you are local (especially if you have a club account). 7/16" XLS is $0.89/foot with a club account, LS is $0.67/foot. The cheapest prices online are at least 20% higher, often 35% higher.
Alex W is offline
post #7 of 13 Old 05-16-2014
christian.hess's Avatar
7/16 on my islander 36...I dont like biggest is better for sheets...but Im used to dinghy sailing
on new line you can go a line smaller than whatever was on the boat stock...but most people dont like to cause they like the biggest feel in their hands
however the benefits are great when going "down" a size
new line is also stronger if staying the same size so that why going "down" a bit or staying small will not cause any issues
for one in light air you have much less weight weighing the sail down
friction is less so sheeting in and out is smoother if using the same hardware as before
and lastly cost, you save quite a bit by not going oversize
and x2 on sta set the normal kind not the x...
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #8 of 13 Old 05-16-2014
azguy's Avatar
5/8th's is way to big/heavy in light air you will not even get it across the deck. I'd just bought some too and found 7/16th's as a good compromise between feeling good in the hands and light enough to pass across the deck in light air.
I bought Sampson trophy braid, just a tad fuzzy and feeling great in the hands..
1988 C22 Owner
azguy is offline
post #9 of 13 Old 05-16-2014
Swab
vega1860's Avatar
That is the problem on a lot of newer small boats. The cleats and other fittings are too small for lines that are comfortable in the hands. I installed larger cleats, blocks and masthead sheaves to accommodate 7/16" rope. 3/8" or 1/4" polyester braid would be strong enough but too hard on my old hands. Larger boats use larger lines but the cleats, IMO, are usually too small for a proper belay. (Trained on a square rigger - no "Yachtie hitches" allowed)
Rope of modern materials is almost always strong enough no matter the size. It is a matter of the right size for your hands and fittings large enough to accommodate it.
+1 on the StaSet-X. Too stiff for sheets. No stretch though. I still have some on my jib tack downhaul.
vega1860 is offline
post #10 of 13 Old 05-16-2014
yeah its the opposite on new boats cause that already factored in with the new line and stuff
also cost wise...
Barlow 24 Self Tailing winches, max sheet diameter krazzz Gear & Maintenance 6 05-15-2014 10:24 PM
Jib sheet blocks jetdrvr393 Gear & Maintenance 12 04-22-2011 04:58 PM
Need a jib sheet mwrohde2 Gear & Maintenance 23 12-30-2008 12:34 AM
Jib Sheet Routing Waugh Gear & Maintenance 14 05-20-2008 02:57 PM
Attaching Sheet to Jib wigwam Learning to Sail 10 10-04-2003 05:29 AM
