Tender or Stiff - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 09-06-2012
Moderator
Jeff_H's Avatar
Re: Tender or Stiff
Originally Posted by davidlaing View Post
Light displacement is not, in itself, a cause of tenderness. A low ballast/displacement ratio is, but the distribution of the ballast matters, too. A boat with a given B/D ratio and a deeply-positioned ballast will be stiffer than a boat with the same B/D ratio but with a more shallowly-positioned ballast.
You are right that "Light displacement is not, in itself, a cause of tenderness." But a boat's ballast ratio really has almost nothing to 'stiffness' as the term as it is used in naval architecture. As classically defined Stiffness is primarily about initial stability (form stability).
Jeff_H is online now
post #12 of 13 Old 09-06-2012
Re: Tender or Stiff
A lot of boats particularly older designs are intended to heel at a certain angle increasing their waterline and thereby their speed. Hence the reason for being initially "tender".
LinekinBayCD is offline
post #13 of 13 Old 09-06-2012
Remember you're a womble
PaulinVictoria's Avatar
Re: Tender or Stiff
There's also the Dellenbaugh measurement which gives you some idea of stiffness of a particular boat. It's a calculation as if 1 pound of force was pushed against a square foot of sail (with some other specifics around it being sheeted central etc). Not an exact measurement but does give some indications around how easily a boat heels. Here's a graph for C&Cs for example, http://cncphotoalbum.com/technical/stability.htm shows you that something like a Mk1 30ft is very stiff, whilst the Mk II turned out to be quite tender. Both sail excellently, so it's not really an indication of how well they sail.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
Water Tender Dingy 9.4 gunnyman1 General Discussion (sailing related) 5 07-11-2008 07:39 PM
Tender marking requirements joub General Discussion (sailing related) 1 02-20-2004 09:15 AM
Fixing wood tender bert2 Gear & Maintenance 3 09-18-2003 08:05 PM
Tank Tender wannasail Gear & Maintenance 1 09-22-2002 07:31 PM
Tender: inflatable or folding? Lucian General Discussion (sailing related) 10 09-02-2002 01:38 AM
