Should I go? - Page 2 - SailNet Community
 11Likes
post #11 of 37 Old 06-12-2014
Re: Should I go?
40 miles beating windward in a 33 ft boat after days of Easterlies in the rain isn't my idea of fun.
You'll be tacking to Portugal then back to Situate In fact, I'll bet you end up in Situate.
How about this, to get some "experience" go but head to Glousta haba instead. You'll be quartering to the SE wind. You'll be cold, wet, but you won't be bashing, and it won't take all the daylight you've got to get there. Have dinner tied up to one of those restaurants on Rocky neck.
jimrafford and Sal Paradise like this.
capecodda is online now
post #12 of 37 Old 06-12-2014
GeorgeB's Avatar
Re: Should I go?
Oops, me bad. Just looked at Google Maps and didn’t appreciate how far north Marblehead is. Lots of beating into short, steep slop. You do it and you will have a BFS tale to tell. To put it into perspective, MrsB and I are going to Tiburon this weekend. And just to make it interesting and kill time while we wait for the tide to fill in at TYC, we are going to do two laps of the Bay. You da man.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #13 of 37 Old 06-12-2014 Thread Starter
Slayer's Avatar
Re: Should I go?
Gloucester is my alternate plan. Everyone thanks for the tips. I will let you know what I do.
Slayer is offline
post #14 of 37 Old 06-12-2014
ASA and PSIA Instructor
Re: Should I go?
Slayer, you're proposing this trip with a sailing club boat? A vessel with relatively limited equipment, and one with which you probably have limited personal experience? No auto pilot, jacklines, EPIRB or liferaft? Such a trip solo, in the best of weather I would think a little iffy, but in rougher conditions, a long stretch. Maybe I have this wrong...
jimrafford likes this.
sailingfool is online now
post #15 of 37 Old 06-12-2014
DrB
MH to P'Town
On a good day with the winds in the right direction and light seas, depending on which side of MH you are (Main Harbor or Salem Side), it's about 8 h at 5.5-6 kts avg.
Done the trip twice, once with my wife and another person, and the other time as part of the Beringer Bowl Overnignt Race. On the return leg from the first trip, we headed back in 6-8 ft seas on the forward beam. Winds were 15kts. We motored sailed at 4.5 kts After 2 h of constant counter-steering, we had to switch off every 3 nm because it was tiring. We decided to bag it after the first two hours and headed to Scituate (22 nm away).
Even if you have 3-4 ft seas, if they are on the nose, you have at least 8 h of this if you can average 5.5 kts. Solo that will be exhausting. and a lot of pounding.
Can it be done, sure. Will you be wiped out physical at the end, 99.9% sure. Will be fun, maybe. If you decide to sail and the wind is from the SE, you'll probably end up sailing almost 80 nm with the tacks.
If you do end up going, I'd stay towards Boston. If it gets to be too much, you can head towards Boston or Scituate.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #16 of 37 Old 06-13-2014
Re: Should I go?
Sort of like the question of "should we reef"? If your asking the question the answer is "yes". If you have to ask "should I go" I think the answer should default to "no". Just my humble opinion. Fwiw.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is online now
post #17 of 37 Old 06-13-2014
Captain Obvious
Sal Paradise's Avatar
Re: Should I go?
Sounds like you should wait it out. The winds are predicted to shift around to the NW on Sunday.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is online now
post #18 of 37 Old 06-13-2014
CapnBones's Avatar
Re: Should I go?
Those conditions sounds pretty good, unless you have to beat in to them, then I would stay in and have some rum. Just curious what your final decision is.
CapnBones is offline
post #19 of 37 Old 06-13-2014
Cruising at a snail pace
Re: Should I go?
sailing out of Salem I've made the PT trip many times, if you go this weekend you better plan on a 2-3 knot VMG speed to come back this weekend
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #20 of 37 Old 06-13-2014
outbound's Avatar
Re: Should I go?
Have done this trip too many times to count and would note.
In the boat you're in ride will be miserable. Although not as shallow as Buzzards Bay sections of Mass Bay generate short square wave chop. Also get reflected waves and confused seas.
In a PSC34 wife and I had to take turns to stay sharp on the helm. Solo with out a good AP or windvane lousy trip.
In a T37 with 4 crew 2 got sick.
Traffic in/out Boston and the C.C. Canal can be significant Without AIS need to keep a sharp eye at all times.
Usual prevailing is light SW winds. Easy reach back and forth in right window.
Fun trip but do it in appropriate window. End of June or Sept/Oct. best as winds die in August.
s/v Hippocampus
Outbound 46
outbound is online now
