06-08-2001
running halyards aft
it is fairly straight foward, insure that the turning blocks arethe correct size. If you want both can be lead to one winch through Jammers, One point here is that you increase the loading on the mast step considerably when doing this. Make sure the step and supporting structure are up to the additional load. On this small a boat I really dont know why you would even be considering this. The associated gear and halyards take up precious cabin top which can better be used for people.
