Lancer Question
I have a 1979 Lancer 28''. Does anyone know where I can get the specs for this boat. Lancer Yachts is out of businees and I need to know how tall the mast is? Can anyone HELP. Thanks. Matt
Lancer Question
I have found the "P" mesurement on the internet as between 27-29'' and the "I" being 32''
LANCER 30-2
Hull Type: Fin Keel Rig Type: Masthead Sloop LOA: 29.50 LWL: 22.50 Beam: 9.83 Draft (max.) 4.50 Draft (min.) SA: 360 Displacement: 7000 Ballast: 3000 Designer: C & C Builder: Lancer Yacht Corp. (USA) Hull: FG Bal. type: First Built: 1977 Last Built: 1982 Number Built: RIG DIMENSIONS: I: 35.00 J: 12.00 P: 30.00 E: 10.00 PY: EY: SPL: ISP: SA(Fore.): 210.00 SA(Main): 150.00 Total SA: 360.00 SA/Disp: 15.79 Est. Forestay Len.: 37.00 BUILDERS:(past & present) More about & boats built by: Lancer Yacht Corp. (USA) DESIGNER: More about & boats designed by: Cuthbertson & Cassian |
Bearman—
I doubt they much care anymore as the posts you are replying to are EIGHT YEARS OLD. If they haven't figured out how to use a halyard to measure the mast....they're probably in trouble... |
Re: Lancer Question
Regards |
Re: Lancer Question
I don't have enough posts to be able to give you a direct link, but you can get that information by searching on sailboatdata.com
Re: Lancer Question
Thanks
Regards. |
| All times are GMT -4. The time now is 06:23 PM. |
SEO by vBSEO 3.6.1
