How to prevent corrosion: SS bolt in Al mast - SailNet Community
 1Likes
post #1 of 11 Old 06-21-2014 Thread Starter
TakeFive's Avatar
I have tapped some threads in my mast. I need an anti-corrosive grease that will prevent galvanic corrosion between the dissimilar metals. I know I've seen this discussed here before, but can't find it right now.
What specific brand names do you recommend for this?
Rick S., Swarthmore, PA
TakeFive is offline
post #2 of 11 Old 06-21-2014
Re: How to prevent corrosion: SS bolt in Al mast
I use Locktite Blue to prevent corrosion on SS to aluminum connections and it seems to work well.)
Gust14882 is offline
post #3 of 11 Old 06-21-2014
Tef-Gel and Lanocote are the two most popular. Both are insulators and they are not going to set up or dry out so it is less likely that the screw will get stuck in the threads. Tef-Gel is expensive and Lanocote is less so. The distributor of Lanocote (Forspar) are supposed to have a new Teflon concoction but I haven't used it.
The best preventive maintenance is to flush all the hardware with fresh water regularly so salt doesn't sit for long.
Maine Sail likes this.
Transmitterdan
1995 Valiant 42
transmitterdan is offline
post #4 of 11 Old 06-22-2014
Master Mariner
capta's Avatar
Any auto parts store will have an anti-seize compound for aluminum. It is copper colored rather than the standard grey. Been using it for many years w/o any corrosion problems between s/s and alloy.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #5 of 11 Old 06-22-2014
I'm sold on Tef-Gel. One small tube (it comes in a syringe) will likely last an owner a lifetime.
I used it years ago to coat the SS screws that hold an access panel to the furler on the mast. Each season, they would be slightly corrode together. After applying, zero issues. In fact, I keep forgetting I did it and find the white grease like paste still there from last year. I've reused them without reapplying for few years now. With some of the recommended products above that dry, you would need to clean them off and reapply each time.
Jeanneau 54DS
Minnewaska is offline
post #6 of 11 Old 06-22-2014
You want the Permatex nickel (silver coloured) anti-seize compound, since if you use the copper-based one you've introduced a third dissimilar metal....
Multihullgirl is offline
post #7 of 11 Old 06-22-2014 Thread Starter
TakeFive's Avatar
What is a good source of Tef-Gel? Some online places seem to want to charge high shipping charges for a little 20 cc tube.
TakeFive is offline
post #8 of 11 Old 06-22-2014
svjobeth's Avatar
I've been able to get it from the local West Marine store, or from an independent chandler in my area.
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is offline
post #9 of 11 Old 06-22-2014
I ordered it from Jamestown Distributors. Not sure of shipping, it was probably combined with a larger order at the time.
Jeanneau 54DS
post #10 of 11 Old 06-22-2014 Thread Starter
TakeFive's Avatar
As usual, West Marine's price for Tef-Gel is about 20% higher than JD and others, but I have $20 in bonus dollars from WM, so I went ahead and ordered it with free shipping to the store in New Castle, DE.
TakeFive is offline
mast step corrosion gweiser Gear & Maintenance 3 03-17-2012 10:08 PM
Mast Step Corrosion follysurf Gear & Maintenance 21 02-10-2012 08:52 PM
mast corrosion - how serious? pic attached tominny Gear & Maintenance 9 01-05-2012 03:35 PM
Mast Corrosion? greencaptn Gear & Maintenance 3 07-09-2007 04:11 PM
Mast Corrosion Repair oldguyflier Gear & Maintenance 5 04-15-2007 11:06 PM
