shocking the water tank - SailNet Community
post #1 of 5 Old 04-16-2006 Thread Starter
Is shocking really needed if we're not planning to use the water in the tanks for drinking?
Is it ok to just flush the anti freeze as much as possible then fill up with water?
ddilman is offline
post #2 of 5 Old 04-17-2006
RichH's Avatar
Definitely needed.
If you wash dishes, or your body with this water, you still need to shock sanitize it.
Especially if you shower with this water then having clean water is a must to prevent respiratory disease.
RichH is offline
post #3 of 5 Old 04-17-2006 Thread Starter
What is the procedure for shocking?
ddilman is offline
post #4 of 5 Old 04-17-2006
sailandoar's Avatar
Check out a previous discussion
Check out a previous discussion: "Drain, Shock & fill water tanks"
http://www.sailnet.com/forums/general-discussion-sailing-related/13748-drain-shock-fill-water-tanks-post57800.html
sailandoar is offline
post #5 of 5 Old 04-17-2006
Originally Posted by RichH
Definitely needed.
Some really nasty diseases can live in the water if the system isn't shocked and maintained. This is a very good point. Psuedomonas is one example of bacteria that can thrive in an untreated freshwater system.
sailingdog is offline
cleaning aluminum water tank rbtpfe9 Gear & Maintenance 18 12-27-2010 11:31 AM
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 04:42 PM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Flexible Water Tank Installation Michael(zuzu) Gear & Maintenance 4 08-15-2005 02:15 PM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 04:17 PM
