Bad Rope (Line/Sheet) Advice? - Page 2 - SailNet Community
 17Likes
post #11 of 27 Old 07-14-2014
christian.hess's Avatar
Re: Bad Rope (Line/Sheet) Advice?
I bought sta set the non x or anything else type and they are prefectly comparable to my old lines...maybe a bit stiffer...
they are simple dacron covered lines...
the x are considered by many way stiff and a poor choice for cruising and or day sailing boats.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 27 Old 07-14-2014
Hi there , First IMO all you needed was StaSet . You didn't say what the line size was compared to what you just bought . If you had say 3/8 and they took you down to 5/16 that might work not so well . The one thing you did say has me thinking ( drilled a hole, put line through) you need to look at that and come up with something where the line won't touch the hole . On my boat I reduced line size from 1/2 to 7/16 and things work better, like the line fits the cleat better. And no that eye splice is not pregnant .
christian.hess likes this.
Westsailforever is offline
post #13 of 27 Old 07-14-2014
GeorgeB's Avatar
Lomcevak, can you provide just a little more information like the various diameters, sizes (and colors too) you bought? That would help me out tremendously. First off, StaSet is double braided polyester line. It is very adequate for recreational, cruising boats (like your Macgregor 26D). StaSet X is dual core, stronger, less stretch and is used for halyards. I believe the “SC” stands for “Solid Color” and “CC” for “Contrasting Color” (But I could be wrong on this). Your boat doesn’t really need the fancy, high priced stuff like Amsteel, Kevlar, or Spectra. I imagine that the halyards (Sta Set X) are 5/16 or 3/8. And the sheets are 3/8. I wouldn’t be surprised if some former owner, shopping the remnant barrel, bought a miss-mash of cordage. Larger diameter sheets have a better “hand”, however, they are heavier and will tend to pull the clew down in light breezes and ruining your sail shape. You might be suffering a little buyer’s remorse. Don’t worry. I remember when I bought my first spectra cored jib sheets. I needed a little over 100’ at $5.35/foot. Ouch. Be happy you’re not addicted to the fancy stuff.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #14 of 27 Old 07-14-2014
thats the exact same color and size got...seems just perfect for my use...
post #15 of 27 Old 07-14-2014
StaSet & StaSetX both have a jacket and a core . The difference between the two is StaSet has a braided core and StaSetX does not, New England claims X has less stretch. Also X is harder to splice .
post #16 of 27 Old 07-14-2014
Over Hill Sailing Club
smurphny's Avatar
If they sold you Sta-Set for your sheets, they didn't do you any favor. Sta-Set and especially Sta-Set X tend to be too stiff and kink too easily. There are much better alternatives for sheets such as plain old Yacht Braid or Salsa (more hi-tech). These have a much better hand and run through blocks easily without binding up. No way would I use Sta-Set for a mainsheet.
smurphny is offline
post #17 of 27 Old 07-14-2014
I did notice that...my JIB sheet sta set kinked amazingy fast and was a nuissance to coil and stow...
however they are new and have not been eased on yet...so I will find out for sure...
the west marine store only had this and not any samson line...which is what I wanted originally based on reviews.
post #18 of 27 Old 07-14-2014
SchockT's Avatar
Honestly I think your first mistake was to rush out and replace all your running rigging after only having sailed the boat twice. I understand the appeal of having all shiny new colorful lines, but I think you would have been better off waiting until you got to know the boat better. That would also have given you time to educate yourself on your options before you went to the store and dropped all that cash!
It's hard to know how good the advice you got was. I am guessing you went to Steveston Marine. If so, the knowledge base is hit or miss. Did you ask for someone who knew about rope, or did you go with the first guy to say "can I help you". Did he ask you questions like what kind of clutches and cleats the boat has? If not, he should have!
For the most part modern ropes are much smaller diameter than their old school equivalents, and yes, that can make them a bit harder on the hands in some situations, but it also reduces friction significantly. The biggest concern with downsizing Halyard diameters aside from the potential for it to jump the sheave is whether the clutches can hold the new rope. Some clutches are sized to a specific rope diameter, and can't hold smaller lines without slipping. Also , if your stoppers are worn they may be able to hold fat fuzzy old rope but have a hard time with the new slippery line. As for chaffe problems, no rope is going to tolerate being dragged across sharp metal edges. That is an issue you should resolve before you replace the rope, and you certainly can't expect the salesman to anticipate such things!
Really, what it comes down to is that you should have educated yourself more before you went shopping. I get my rope advice from riggers not retail salesmen! Even posting here first would have better prepared you. Having said that, you will probably be fine with most of the lines you bought!
Now get out sailing and figure out what works and what doesn't!
Andrew65 likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #19 of 27 Old 07-14-2014
smurphny's Avatar
Last year, in a West Marine down in Florida, I found a cut length of 10mm Salsa for an unbelievable price. I think it must have been mis-marked, like $69 for 90', just long enough for my mainsheet which was getting pretty worn out. The original was 7/16" standard Yacht Braid. The Salsa (although brightly colored has been very good as a sheet line and I'd definitely recommend it for this use. It is even more pliable than the Yacht Braid. The other great thing about the Salsa is that it's not double braid which is a royal PITA to splice. 12 strand is easy-peezy.It does pay to keep an eye on the spool end pieces in stores.New England Ropes - Product Details
smurphny is offline
post #20 of 27 Old 07-14-2014
I've got nearly a whole roll of new samson dacron 3/8 with a blue marker and another of soft 7/16 white braid sitting in the basement. Offering at 1/2 price of WM. A couple of inches of vinyl hose where it goes thru the bee hole helps the issue. .I don't splice any more but if I can do it ,you can learn too. Sold the tall ship.
Capt Len is offline
Blown main sheet traveler car- need advice ASAP sailtobike Gear & Maintenance 11 10-11-2012 01:44 PM
PSC 31 sheet/halyard/line lengths AlLorman Pacific Seacraft 11 04-22-2012 11:21 AM
Rope/Line Terminology Question Kunikos Gear & Maintenance 24 07-17-2010 09:42 AM
Single line jib sheet, what kind of splice is this? johnnyandjebus General Discussion (sailing related) 22 03-27-2010 06:14 PM
Was I Out-of-Line? Deal gone bad catfish26 Boat Review and Purchase Forum 32 12-15-2008 11:50 AM
