Sailing around the world on a Catalina 22 sailboat - Page 2 - SailNet Community
 43Likes
post #11 of 76 Old 07-15-2014
Owned by Velcro
Ferretchaser's Avatar
Re: Sailing around the world on a Catalina 22 sailboat
Originally Posted by Mr. Bubs View Post
Go for it. I plan on circling the planet in my Macgregor 25 death machine.
At what altitude
They fly so I was told
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #12 of 76 Old 07-15-2014
RichH's Avatar
Nope not at all; since the 'structural design' of the C22 is strictly for 'inshore' or protected waters sailing.
An around-the-world boat of this size would be built to at least TWICE the 'strength' of a C22.
Inotherwords ... expect the C22 to 'fall apart' (and probably sink) long before you complete your circumnavigation. There's simply not enough 'reserve strength' (safety factor) in an inshore design boat to take the beating that a dedicated 'blue water' boat can handle .... This has NOTHING to do with the experience and ability of the sailor; its just simple 'material and inbuilt design strength'.
RichH is offline
post #13 of 76 Old 07-15-2014
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by Minnesail View Post
And since mine is a swing keel if you did get knocked down much past horizontal there's a chance that the keel could slam back up.
The swing keel Catalina 22 boats I have sailed have had a big pin that holds the keel down.
SVAuspicious is offline
post #14 of 76 Old 07-15-2014
Minnesail's Avatar
I don't know anything about the design of "offshore" boats, but I can say that a C22 is pretty soft. I cut a backing plate out of G-10 fiberglass and that stuff is crazy impossibly hard. Then I went to cut a through-hull in the C22 and it was like cutting through butter in comparison.
They have a screw that pushes against the side of the keel and friction is supposed to keep it down, but it doesn't really lock it in place. The consensus on the C22 forum is that if you got much past horizontal the weight and levering effect would rapidly overcome the the friction of the end of a 1/2" screw. A lot of peep have removed the pin and glassed over the hole, since it can let water in sometimes.
In my mind I think of it as a keel brake, rather than a keel lock.
Catalina 22
on a starboard tack
Minnesail is offline
post #15 of 76 Old 07-15-2014
first sailed january 2008
northoceanbeach's Avatar
Don't forget there are a lot of fixed keel Catalina 22's. That being said, and having owned it as the second of my five under 30 foot boats, I felt it to be the weakest. Although it 20-30 knot hawaii winds and 4-6 foot seas it always sailed great. I'm all about taking a small boat offshore(at least wanting to). This would not be it.
northoceanbeach is offline
post #16 of 76 Old 07-15-2014
Philzy3985's Avatar
With perfect weather windows it's probably possible. You'd have to have a lot of patience, and not need a lot of food or water storage.
Realistically yes, a 22 foot sailboat can do it - but you'd want the 8,000 lb full keel, heavy-built kinds, not a C22, if you were asking for a personal reason.
You'd have to do more modifications to it all over that it would just make sense to buy a sturdy sailboat.
I have a sabot. Thought about doing the trans-pac in it.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
Philzy3985 is offline
post #17 of 76 Old 07-15-2014
Captain Obvious
Sal Paradise's Avatar
..There's simply not enough 'reserve strength' (safety factor) in an inshore design boat to take the beating that a dedicated 'blue water' boat can handle .... This has NOTHING to do with the experience and ability of the sailor; its just simple 'material and inbuilt design strength'.
Catalina would certainly disagree with you. They say it is " safer at sea and in all conditions than any boat in it's class " And the thousands of C22's still out there sailing decade after decade after decade must all be very lucky or very careful .
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #18 of 76 Old 07-15-2014
GeorgeB's Avatar
Not to stoke the fires, but Catalina did make a fixed fin keel version of the boat during it's long, long, production history. Once, I did a round trip to Monterrey from Santa Cruz over a weekend. If any of you are familiar with Monterrey Bay in th afternoon, you will understand when I say I had my Cape Horn rounding experience!
Minnesail and christian.hess like this.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #19 of 76 Old 07-15-2014
TakeFive's Avatar
This just seems like an absurd idea. Any C22 or similar boat would have to be modded so extensively that you might as well just buy a boat designed for the task anyway. It's not just the swing keel - it's basically the whole boat. Even if the boat was durable enough, there's just not room for the needed gear and provisions. And hit just one storm and it would swallow up the boat like nothing.
Originally Posted by Sal Paradise View Post
Catalina would certainly disagree with you...
I dare you to find me someone at Catalina who would advise taking a C22 on a circumnav.
...They say it is " safer at sea and in all conditions than any boat in it's class " And the thousands of C22's still out there sailing decade after decade after decade must all be very lucky or very careful .
I doubt their promotional literature that you supposedly quote has that grammar error (possessive its with apostrophe). And the key phrase there is its class. It is very safe for its class, but its class is cruising and daysailing in protected waters.
The correct answer to OP's original question is "no."
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #20 of 76 Old 07-15-2014
christian.hess's Avatar
not quite cape horn jajaja but thats exactly where I ripped a jib coming down from halfmoon bay
blows like stink there
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Tags
around the world , catalina 22 , circumnavigation , ocean , sail
Sailing around the world on a $10,000 sailboat khammett General Discussion (sailing related) 43 08-10-2014 05:27 PM
Sailing around the world in a small sailboat chriscross80 General Discussion (sailing related) 10 07-29-2014 10:31 PM
Saildrone: New World Record for Autonomous Sailboat - Scuttlebutt Sailing News NewsReader News Feeds 0 11-17-2013 08:30 PM
Fastest Sailboat in the World - Speed Sailing Record - YachtPals.com News NewsReader News Feeds 0 11-18-2012 07:30 AM
Sailing in Marin: World's largest sailboat owner has passion for finding leukemia and NewsReader News Feeds 0 10-15-2012 06:00 PM
