Boom on Venture 21 - SailNet Community
post #1 of 16 Old 07-18-2014 Thread Starter
Boom on Venture 21
I stepped the mast for the first time on our new to us Venture 21 and after hooking up the boom it seems alittle low. My question is can you raise it? After we raised the main sail we realized there is a bit of slack in it... Is that normal when yard yachting? (aka not on water and making sure everything works properly) or should the sail have tension in it? If I raise the boom it will have more slack in it than before is that ok? Please let me know.
creelclmsn is offline
post #2 of 16 Old 07-18-2014 Thread Starter
Re: Boom on Venture 21
No one knows if you can raise the boom up? I find this hard to believe!!! You guys are such a great source of information on every topic I have had!!!! Don't fail me now guys
post #3 of 16 Old 07-18-2014
Minnesail's Avatar
From the drawing here VENTURE 21 it looks like the boat has a low boom.
My boat is a similar size and vintage and the gooseneck on my boom slides up and down the sailtrack on the mast. It has little screw-in stops to keep it in place.
Catalina 22
on a starboard tack
Minnesail is online now
post #4 of 16 Old 07-18-2014 Thread Starter
Mine is even lower than that... Is the slack in the Main sail ok or no?
post #5 of 16 Old 07-18-2014
Mark1977's Avatar
Pics. would help allot.
Mark1977 is offline
post #6 of 16 Old 07-18-2014
Minnesail's Avatar
Slack in life is good. I've got slack.
Slack in a sail is bad. Something needs to be fixed.
Catalina 22
on a starboard tack
post #7 of 16 Old 07-18-2014 Thread Starter
Ok but I am talking about with no wind, sitting in the drive way should there be a bit of slack in the sail?
post #8 of 16 Old 07-18-2014
El Chupa Nibre
Mr. Bubs's Avatar
Do you have a photo? A direct side view would be helpful. You may have the rake (angle) of the mast wrong.
Mr. Bubs is offline
post #9 of 16 Old 07-18-2014
The most female moderator
Donna_F's Avatar
Dock
If there's absolutely no wind, the sails will be slack because there isn't any wind to fill them. Like they'll look if you point directly upwind on the water.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
post #10 of 16 Old 07-18-2014 Thread Starter
I would post pics but it wont let me
Mac/Venture 22 boom dimensions tidal9 MacGregor 0 11-30-2012 05:59 PM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 10:33 PM
broken boom mid-boom sheeting problem? somedaypam Gear & Maintenance 15 10-23-2007 05:22 PM
