Trying to ID this small sail/row boat - SailNet Community
post #1 of 5 Old 07-22-2014 Thread Starter
I'm trying to identify this small boat. I'd like to figure out if it is worth getting it back in the water, and if I know the model it will make it easier to find parts. It looks like it is comparable to the AMF Puffer, but it doesn't look like a Puffer variant.
Here is an album of more photos
There are a set of oar locks on the gunwales, and there are screws protruding from the slot for the daggerboard, which makes me thing there was probably a bench across there where the rower could sit. There are fittings for stays on the gunwales as well, so I'm guessing the rig was not fully freestanding.
If the hull is in decent shape structurally, I can probably find or improvise enough rigging to get it in the water without spending a lot of money. Once I know the model I can start searching various forums for the tiller, daggerboard, mast, boom, sails, etc. or get enough info about the proper dimensions to find/fabricate substitutes.
Thanks for any help.
Last edited by revmike; 07-23-2014 at 12:42 PM. Reason: added photo info - updated to more reasonable size photo
revmike is offline
post #2 of 5 Old 07-22-2014
Singlehander by Default
nighthawk's Avatar
Re: Trying to ID this small sail/row boat
Either keep posting here until you have enough or go to the Song Chain, or some other thread and post there until you can post pictures. Your descprition could be one of hundreds (maybe even thousands) of sailable dinghies or small trailer sailers. If you can find the Hull ID Number, post the first three letters-that will tell the manufacturer (see fellow SNers, I listen) and at least give you a place to start.
Spencer
Laguna Windrose 22 "Wind Angel"
Catalina 16
Visit my blog--
~~When you decide to become a sailor, you start with a full barrel of luck and an empty cup of experience. The trick is to fill your cup before the barrel runs dry.~~
Last edited by nighthawk; 07-22-2014 at 04:16 PM. Reason: Because some days I don't read carefully enough
nighthawk is offline
post #3 of 5 Old 07-22-2014 Thread Starter
I'll go and try to get enough posts to add the images directly, but if you copy imgur.com/a/SGS6T/all and paste it into your web browser, you'll see the images I have.
revmike is offline
post #4 of 5 Old 07-23-2014
Sailor of Small Waters
Looks a lot like an AMF Force 5, but not quite right. Cockpit's too long. I don't think it had a full rowing bench as there aren't visible mounts on the sides for the ends of the board. I'd bet the screws were for wood trim on the daggerboard trunk.
1981 Vagabond 14 "Firefly"
196(8?) Douglas & Mcleod Thistle #2694 "Old Dog"
Jack Sparrow think's I'm a Commodore
Why does everyone think my name is Clyde...?
ultraclyde is offline
post #5 of 5 Old 07-23-2014 Thread Starter
Thanks for trying. Definitely not a Force 5. My family had a Force 5 growing up and I'm familiar with it. The cockpit of this boat is bigger. Also the mast is stepped just forward of the daggerboard, but aft of the foredeck decking. The Force 5 has a mast stepped through the forward decking. Finally, the Force 5 had a freestanding mast, while this boat has stays on the sides.
revmike is offline
Retro fitting a propane locker in a small sail boat downeast450 Gear & Maintenance 47 05-25-2016 05:13 PM
A Long Sail with Courtney on a Very Small Boat. gedaggett General Discussion (sailing related) 25 09-28-2010 06:58 AM
Small Boat Sail Repair wastvedt Gear & Maintenance 2 03-26-2008 12:36 PM
newbie looking for small sail boat theloveboat Boat Review and Purchase Forum 3 05-11-2007 10:32 PM
Raw Nerve wins third Gladstone in a row @ Sail World Australia NewsReader News Feeds 0 04-15-2006 03:16 AM
