Music Etiquette at the Dock - Page 4 - SailNet Community
 37Likes
post #31 of 82 Old 07-24-2014
Full-time Liveaboard
CaptainChaos's Avatar
Re: Music Etiquette at the Dock
Originally Posted by capta View Post
We almost ALWAYS anchor beyond the last boat, so it's not like we squeeze into the middle of the crowd and disturb everyone. The genset is absolutely indispensable to most of us who cruise, and I feel absolutely no guilt if someone anchors down wind of me. There are usually plenty of spots to windward of us and the second, smaller exhaust on the transom should indicate to any observant skipper that I have, and use a genset.
I find the cheap, noisy windgens much more intolerable to have around, because, unlike a portable generator, the noisy, cheap windgens make life miserable for everyone around them, 24 effing hours a darned day! There otta be a law!
Yes, a genset is very useful on a cruising boat but I still think quiet hours should be observed. Run it during the day if you need to recharge batteries, run the AC during the hottest part of the day, etc. but at night please let those of us that wish to enjoy the quiet of the night have our time, as well.
Walt
s/v Wanderlust
Passport 545
CaptainChaos is offline
post #32 of 82 Old 07-24-2014
travlin-easy's Avatar
I'm installing a genset this year, mainly because my lungs are shot to Hell and it makes breathing a lot easier when I can run the boat's AC system. The one I'm looking at is the Ryobi 2200, which sells for half the price of the Honda 2000, has better specs and is only slightly louder in DB. It also has an idle feature, which allows the generator to drop to idle speed when there is no load. Generally, it's quiet enough to hold a conversation at normal level within 10 feet of the generator running full power. I like that.
I'll have to build a special platform for it on the boat's stern, something similar to a swim platform. I know guys that hang them from the stern rail, but I'm not happy with that arrangement, and I think the platform would provide better protection from exhaust fumes coming into the cockpit. I do, however, highly recommend installing an explosive gas alarm in the cabin, just to be on the safe side. The alarm detects all gasses, including carbon monoxide, even in the tiniest amounts. The alarm is loud enough to wake you from a deep sleep.
Good Luck,
Gary
travlin-easy is online now
post #33 of 82 Old 07-24-2014
Philzy3985's Avatar
The thing about music is that not everyone around has shares your taste.
So, the balls in your court whether to show neighbors respect or disrespect. I love my music at the dock, too, but if someone gives me just one look, I'll turn it down or off in a heartbeat. Fortunately my immediate neighbors and I all tolerate and enjoy whatever is turned up.
I wish this was the case for the drunk fisherman and his fat bellied buddies who flip on blue tuna-tower LEDs at night and blast pandora country radio - with commercials no less.
davidpm likes this.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
Philzy3985 is offline
post #34 of 82 Old 07-24-2014
Master Mariner
capta's Avatar
There is a HUGE difference between a genset and a portable generator, unless you have a cat with the exhaust between the hulls. If you can hear mine run at all, you will hear the water coming out of the exhaust only, not the engine. As I said, if someone chooses to anchor downwind of me, then it's on them, if the genset exhaust bothers them, but w/o the genset, I don't get a hot meal in the morning and evening, never mind refrigeration and battery charging.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #35 of 82 Old 07-24-2014
Master Mariner
capta's Avatar
Good Luck,
Gary
If you can find a water cooled generator or a genset to install you would probably be a lot happier in the end, if this is something you are going to use a lot.
A few extra dollars spent now could make a huge difference in livability aboard and just not having to deal with gas is worth a lot to many of us. A used RV Onan can be had pretty inexpensively and adding a heat exchanger (but at our age, even salt water cooled, it would probably out last our boating lifespan) and s/w pump, could be done simply and cheaply. Your neighbors would definitely appreciate it.
davidpm likes this.
Our Videos;
capta is online now
post #36 of 82 Old 07-24-2014
pdqaltair's Avatar
... then it's on them, if the genset exhaust bothers them, but w/o the genset, I don't get a hot meal in the morning and evening, never mind refrigeration and battery charging.
Oh dear....
a. No hot meal. No propane or diesel?
b. The refrigeration is that power greedy?
My stove, microwave, and fridge work just fine without generator. Huh?
I guess my standard for quite in an anchorage once the sun goes down is different. Dead quiet. And the notion that I have the right to change that for others is, well, greedy. The notion that someone else should have to move because of me is greedy. The more crowded the anchorage the more it falls to each of us to go above and beyond to be polite.
I'm sure your genset is quiet. I doubt it is dead quiet. As for what is down wind, that changes by the hour in many places and so is a frivolous defense.
CaptainChaos and WGEwald like this.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #37 of 82 Old 07-24-2014
Capta. do you have a link? I would install one, if, and only if, I can find room in the engine room and if it's under $600. I hope I do not need to use it very often, and in the Florida Keys, I had to tie up to the dock to obtain shore power so I could keep the humidity level down in the boat to protect my music gear, and of course, so I could breath easier without the use of steroidal inhalants. Gettin old ain't fer wimps and sissies.
Gary
post #38 of 82 Old 07-24-2014
If you were a good judge of paradise you could be where the air is cool, dry and pleasant and the people polite and considerate .
Capt Len is online now
post #39 of 82 Old 07-24-2014
chef2sail's Avatar
Wear earbuds...they cant hear you....and you cant hear them
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #40 of 82 Old 07-24-2014
Master Mariner
capta's Avatar
Originally Posted by pdqaltair View Post
Oh dear....
I am so happy for you that you never have to run a generator, but some of of us just don't have all the modern systems available today. As a matter of fact, when my boat was built, it was against USCG regs to have propane aboard any boat for hire.
As for the wind shifting, you've obviously spent little or no time in the Caribbean, as you can probably count the days a year when the wind isn't easterly, on the fingers of one hand. Anyway, I certainly won't be bothering you in MD.
But I don't really understand why are you even bothering to respond to my post. You would be anchored in ten feet of water up by the beach, with all the other cats, probably half a mile to windward of me. So let's get real here, you certainly wouldn't be able to hear anybody's portable generator, let alone someone's genset, at that distance, up wind. You'll just have to come up with some other excuse for having another sh*tty evening in paradise.
Our Videos;
capta is online now
Dock or Dry Dock I can't make up my mind ABH3 Boyer General Discussion (sailing related) 17 11-22-2013 04:41 PM
etiquette? SailerDoc2 Learning to Sail 49 11-30-2011 11:13 PM
Mr. Music Please! pinayreefer Gear & Maintenance 11 08-01-2011 11:34 PM
