Herniated jibsheets - Page 2 - SailNet Community
 3Likes
post #11 of 18 Old 07-25-2014 Thread Starter
Re: Herniated jibsheets
Osprey26 has me confused too....
Yeah, soft shackle or spectra loop with cowhitch. Duh, should have thought of that. Gives me an excuse to play with Dyeema - wonderful stuff. Thanks guys.
paul323 is offline
post #12 of 18 Old 07-25-2014
I think he means 'leave the engine running, engage to tack.'
Capt Len is online now
post #13 of 18 Old 07-25-2014
Master Mariner
capta's Avatar
We use about 3' of small dyneema to lash the spliced eyes in the sheets to the clew. Nothing fancy, just lashing and a few knots. Haven't had any failures in over 3 years (or had any wear on the dyneema), beating into 35 knots of wind or so occasionally, and 25 pretty regularly, on a boat weighing around 70k pounds.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #14 of 18 Old 07-26-2014
Originally Posted by paul323 View Post
Just finished making a sail from Sailrite - interesting experience, seems to be working well. But one issue - the steel D-ring used on the clew has a small diameter. Strong enough, but tough on the sheets. I use 1/2 sheets - they fit well in the winch 'tailer, and are easy on the hands - but the tight turn around the D-ring causes the core to burst out (it's a heavy-wind blade, so there is a lot of tension on the sheets upwind).
I tried a smaller diameter sheet, but that slips on the winches.
Any suggestions? My working jib and genny both have large eyelets, offering a bigger radius for the turn; never been a problem. So it's just the new blade.
Congratulations on making your own sail; quite an achievement in itself. Since you are familiar with using the sewing machine, why not just sew in a larger ring?
Seaduction is offline
post #15 of 18 Old 07-26-2014 Thread Starter
Good question...lazy I guess. First I would have to cut the leather chafe cover. Underneath, the ring is held in place with 3 sets of webbing, about 1' each... (as I recall), and reinforced in place with waxed twine...that would all have to go.
I would also have to remove the sacrificial cover, and likely some of the trim tape on the foot and leach.
Then fit the new ring and reverse the process...
So it could be done but the layup on the three corners is enormous, especially at the clew; as I recall it is something like 7 layers of 7.5" dacron, plus the tape and sunbrella...even my trusty old Sailrite couldn't handle the whole thing, so it would need to be hand stitched.
So all in all, 3-4 hours work.
Or I can make a spliced Dyeema loop in about 15 minutes,
Hmmm...let's think about this....
tomandchris likes this.
paul323 is offline
post #16 of 18 Old 07-26-2014
But how does that pertain to the discussion. Good thing that the OP has already got his answer!
tomandchris is offline
post #17 of 18 Old 07-26-2014
Why not make a Dyneema loop. Sounds like a lot less trouble.
post #18 of 18 Old 07-31-2014
kgs113's Avatar
I'm a real big fan of the soft shackle too. Bowline on the ends of your jibsheet and run continuous. Never have to worry about losing a sheet. Sail changes are easy if you have the need.
Originally Posted by MarkofSeaLife View Post
Wot? Like this??
kgs113 is offline
How to run my jibsheets? Toller Gear & Maintenance 4 06-17-2014 11:15 PM
Jibsheets palacegrand Gear & Maintenance 7 11-29-2004 06:20 PM
jibsheets while spinnaker''s up dpboatnut Racing 6 04-09-2004 07:21 AM
Attaching Jibsheets Dan Dickison Gear and Maintenance Articles 0 03-04-2002 07:00 PM
