Herniated jibsheets - SailNet Community
 3Likes
post #1 of 18 Old 07-25-2014 Thread Starter
Herniated jibsheets
Just finished making a sail from Sailrite - interesting experience, seems to be working well. But one issue - the steel D-ring used on the clew has a small diameter. Strong enough, but tough on the sheets. I use 1/2 sheets - they fit well in the winch 'tailer, and are easy on the hands - but the tight turn around the D-ring causes the core to burst out (it's a heavy-wind blade, so there is a lot of tension on the sheets upwind).
I tried a smaller diameter sheet, but that slips on the winches.
Any suggestions? My working jib and genny both have large eyelets, offering a bigger radius for the turn; never been a problem. So it's just the new blade.
paul323 is offline
post #2 of 18 Old 07-25-2014
weinie's Avatar
Re: Herniated jibsheets
Attach 1 bowline to the other bowline maybe?
weinie is offline
post #3 of 18 Old 07-25-2014
Old as Dirt!
svHyLyte's Avatar
Make up, or if you can't splice, have a local rigger/sail maker make up, a loop of spectra, pass that through the clew cringle in the manner of a cow hitch and secure your sheets to the loop.
FWIW...
svHyLyte is offline
post #4 of 18 Old 07-25-2014
Paul,
How are you currently attaching the sheet? I use a lark's head and to make things easy, I have some whipping twine at the very midpoint of my sheet. (I re-rig every sail) So, in kind, could you pull the cover of of about 6" of StaSet or Spectra of the SAME diameter as your sheet and milk it all the way to the middle? Pull it tight and stitch into place with twine or UV protected thread. Or, take 1/32" line and wrap the grommet thereby increasing the working diameter? Either way it's 15-30 minutes of work.
DonScribner is offline
post #5 of 18 Old 07-25-2014
MarkofSeaLife's Avatar
Dock
As a cheap way... can you put in an old shackle.......
OK lets can that idea right here and now... just thought about a flogging genoa with a shackle dancing round the foredeck. LOL
Go with svHyLyte's advice.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #6 of 18 Old 07-25-2014
From time to time we do have to go back to basics of sailing. It is easier to make adjustments going in to the wind. In stronger winds does require to be little bit quicker. Motoring of one kind or the other also helps to point in to the wind and get out of irons after.
Oh well some of us are spoiled by using this technology to get out of marina and start sailing.
Sorry learning.
Osprey 26 is offline
post #7 of 18 Old 07-25-2014
weinie's Avatar
dyneema soft shackle?
paul323 and MarkofSeaLife like this.
weinie is offline
post #8 of 18 Old 07-25-2014
Dock
Wot? Like this??
Sea Life
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
oysterman23 (07-25-2014)
post #9 of 18 Old 07-25-2014
johnnyandjebus's Avatar
What weinie said, soft shackle. I replaced my hard shackle with a soft one last year and haven't looked back. Easy enough to make and plenty of examples on the net. Best thing being you have nothing to lose in trying as you don't have to alter your existing setup.
John
"The more I know about people, the better I like my dog."
-- Mark Twain
"If you canít explain it to a six year old, you donít understand it yourself.Ē
--Albert Einstein
johnnyandjebus is offline
post #10 of 18 Old 07-25-2014
Sorry learning.
???????????? Translation please!
tomandchris is offline
How to run my jibsheets? Toller Gear & Maintenance 4 06-17-2014 11:15 PM
Jibsheets palacegrand Gear & Maintenance 7 11-29-2004 06:20 PM
jibsheets while spinnaker''s up dpboatnut Racing 6 04-09-2004 07:21 AM
Attaching Jibsheets Dan Dickison Gear and Maintenance Articles 0 03-04-2002 07:00 PM
