Major Problems With Marina - Page 4 - SailNet Community
post #31 of 34 Old 11-28-2007
So how did it all turn out???
Chris
witzgall is offline
post #32 of 34 Old 11-28-2007
I don't like the sound of all of this.
Water in the fuel would not do it.
Hydraulic lock probably would.
This would explain the chewed starter and flywheel... solid and abrupt lock-up. An experienced mechanic would be mindful of the possibility of it though, and would not crank and crank and crank with the water feed open.
Even with the feed open, it really is not likely to flood the cylinder(s) until the cranking stops.... you would hear it gurgling down.
If it ever happens to you, you have to pull the injectors out and suck with a straw and spit it out (been there, done that). It's not a big job pulling the injectors.
I am puzzled.
It's a blow to have a 3 year old motor crashing like that. I would avoid lawyers, if only to save nervous energy. It might be better to buy another motor, and use the first as spare parts. You will have plenty, for the forseeable future.
Rockter is offline
post #33 of 34 Old 11-28-2007
1987 Pearson 27
Joel73's Avatar
Witz...
I doubt you'll get a reply anytime soon seeing as how that member has only posted 4 times this year... BUT...Did you see this thread:
a (semi) happy (almost) ending to my saga
"Unthinking respect for authority is the greatest enemy of truth." - Albert Einstein
Joel73 is offline
post #34 of 34 Old 11-28-2007
Basically, from what the OP said, the marina screwed up... hydrolocked his boat's engine and then tried to cover it all up. I don't know what he did...since he hasn't posted an update beyond what was in the other thread.
Generally, cranking any diesel with a water-lift muffler for any longer than 20 seconds is going to risk hydrolocking the engine. Even cranking it for 10-15 seconds repeatedly can risk it if you don't wait long enough between attempts.
sailingdog is offline
Hammond, Indiana, Marina effectively destroyed jdkirkk General Discussion (sailing related) 4 03-01-2006 10:43 AM
regatta pointe marina soaringwind3 General Discussion (sailing related) 11 06-25-2005 04:22 AM
Regatta Pointe Marina - Rezoning! blackhat General Discussion (sailing related) 10 08-12-2004 12:38 AM
Regatta Pointe Marina - FIRE!!! Awareness Program blackhat General Discussion (sailing related) 1 07-01-2004 03:37 AM
Marina Del Rey live aboard question Myblueheaven Living Aboard 1 10-14-2003 11:22 AM
