Sails - SailNet Community
post #1 of 4 Old 04-23-2006 Thread Starter
Sails
wondering if anyone knows if say sails from an oday40 could be used on a 35 c&c or how you can transfer sails what are the rules on that??? any help would be great
normontess is offline
post #2 of 4 Old 04-23-2006
Moderator
Jeff_H's Avatar
Its pretty unlikely that you can use any sails from an Oday 40 on a C&C 35. The rig propotions are very different.
Jeff_H is online now
post #3 of 4 Old 04-23-2006
run over to www.baconsails.com and choose search by factory dimensions, then you can compare the two sails easily. (open in two tabs for easier comparison)
It's a pretty comprehensive set up over there.
Ken
merc2dogs is offline
post #4 of 4 Old 04-23-2006
ASA and PSIA Instructor
Norman,
No rules on this subject, whatever fits can fit, for better or for worse. As to this particular exchange, Jeff calls it correctly, you can check the rig dimensions at http://www.mauriprosailing.com/techi.../boatspecs.htm
If you start to consider cutting down a used sail, or even having to re-tape the luff for a different system, then any savings start to disappear in the labor cost and you may be better off buying no-name sails new.
However if you want to press on with the subject first read up on how to measure sails, say at http://www.secondwindsails.com/measurement.php
Compage the measurements of the two boats,
sailingfool is online now
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 01:19 AM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
