docking with no motor and 20 knots - SailNet Community
 28Likes
post #1 of 52 Old 07-30-2014 Thread Starter
Borrowed Chrysler 22' swing keel. Ignition key broke off, didn't think id have a motor. Wind was 20 knots from the north, dock was to our south. The slip faces east/west, other boats all around and their sterns extending past the docks. Ended up getting motor on , but how would I have docked otherwise?
FlyingJunior is offline
post #2 of 52 Old 07-30-2014
TakeFive's Avatar
Re: docking with no motor and 20 knots
Anchor and call for a tow, or...
Sail gently into fuel dock or T-end and wait for conditions to calm while plotting next steps, or...
Learn how to hot-wire your motor. It may come in handy.
JimMcGee and Andrew65 like this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #3 of 52 Old 07-30-2014
with 20 knots on your stern you could probably drop the sails and let the wind push you down the fairway then turn into the slip. Unless I'm missing something..
tempest is offline
post #4 of 52 Old 07-30-2014 Thread Starter
When I turn west towards the slip I'd have to be right on, no mistakes. Also can't control speed of entry ( I subscribe to - one should only enter at the speed they're willing to hit the dock at). No reverse gear. Can't enter on a beam reach reefed. Too tight, no room for the boom to swing, would have to ease it way out to slow the boat on a reach.
post #5 of 52 Old 07-30-2014
if you think you're going too fast, even with the sails down, you can drop a bucket off the stern. I keep one onboard with a strong handle and a rope for rinsing the deck etc.
to slow down..you could also make a series of short sharp turns port and starboard..using the rudder to help brake you...
assuming you have your fenders out and docklines and a spring line ready..you shouldn't have that much way on that you can't stop a 22 ft boat with a cleat and a spring line without doing damage.
Next time you dock with your engine working with wind astern..put it in neutral/idle early and see what happens.
davidpm, AlaskaMC, Group9 and 3 others like this.
tempest is offline
post #6 of 52 Old 07-31-2014
Drop sails, 200 ft from your slip toss the anchor. now you're head to wind and dead in water. Pay out rode till opposite slip. Back jib to close with open slip. get line (s) ashore .Receive complements from witnesses and crack a beer. Hope somebody puts it on u tube (retrieve anchor before some one else does)
Andrew65 and Sal Paradise like this.
Capt Len is online now
post #7 of 52 Old 07-31-2014
Remember you're a womble
PaulinVictoria's Avatar
My first step would be to wonder why a 22' boat with an outboard really needs electronic ignition/start, then I'd hunt for the backup pull cord.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #8 of 52 Old 07-31-2014
Master Mariner
capta's Avatar
There is absolutely no reason to consider this question. Anchor or heave to outside the marina and call for a commercial tow.
Should anything go wrong in your attempt to sail into your marina in 20k of wind, I'd bet it would cost you much, much more than the tow would. Attempting to sail into anyplace that you do not need to, in adverse conditions is foolhardy, dangerous and poor seamanship. Display your common sense and seamanship by not risking your boat and those of others, wrecklessly.
JimMcGee and davidpm like this.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #9 of 52 Old 07-31-2014
As often happens with limited information, I misread this as him already in the marina heading for the slip, when the engine died. By all means, if you're outside the marina, drop an anchor, drop the sail..deal with the engine or get a tow if needed.
tempest is offline
post #10 of 52 Old 07-31-2014
Over Hill Sailing Club
smurphny's Avatar
You can do a lot with a couple of anchors, "walking" your way from one to the other. Also, with a 22' boat, those ancient devices called oars can be utilized:-) I have seen good sailors get large sailboats, under sail, into incredibly difficult spots with adverse wind and currents. No way I am good enough to dare to attempt such maneuvers but it is possible. It is awesome to watch what can be done under sail when a master sailor is at the helm.
smurphny is offline
MOB doing 20 knots in 30 knots + recovery AdamLein General Discussion (sailing related) 30 02-11-2012 12:53 AM
Docking in 25-35 Knots -- Your Technique? NCC320 Seamanship & Navigation 95 02-17-2009 06:41 PM
Have I Gone Knots? SEMIJim General Discussion (sailing related) 26 12-31-2008 12:52 PM
knots Alden68 General Discussion (sailing related) 57 03-20-2008 09:26 AM
Knots SEMIJim Learning to Sail 10 07-04-2007 06:40 PM
