keel cooling - Page 2 - SailNet Community
 10Likes
post #11 of 21 Old 08-01-2014
christian.hess's Avatar
Re: keel cooling
you have a steel boat right? its pretty damn easy to rig on a steel boat, especially of you are in colder waters...
I like the idea if using the hollow skeg as the cooler too
pics?
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #12 of 21 Old 08-02-2014
Wingnut
Re: keel cooling
I almost have a steel boat.
Still sitting inn the yard.
So, yeah it is easy to do with steel, and evenn easier to do if you are building it yourself from scratch.
Maybe i will upload a bunch of pictures one day, but for now, I dont have time.
Dirtyfloats is offline
post #13 of 21 Old 08-02-2014
fallard's Avatar
Re: keel cooling
Our Isotherm in-water heat exchanger is a coil inside the bronze thru-hull fitting for our galley sink drain. The coil is completely within the hull fitting. The fitting itself looks much like a conventional fitting, but a little wider and notable for the ring of 1/4" perforations, and protrudes perhaps 3/16" so as to produce little disruption in flow over the hull. The first year we used a special zinc, but it proved unnecessary and we haven't used it since (at least 10 years).
We see absolutely no fouling inside the hull fitting and the coil is perfectly clean. My understanding is that the darkness inside the fitting and the heat associated with its function are more than sufficient to eliminate growth.
Minnesail likes this.
fallard is online now
post #14 of 21 Old 08-03-2014
fallard's Avatar
Re: keel cooling
Here's a picture of the isotherm thru hull. The center is carries the drain from the galley sink. The perforations allow water flow into the cooling coil area. Two of the perforations are threaded to accommodate a special zinc--if you need to use one. The marelon thru hull to the left accommodates a 5/8" raw water intake hose (for scale).
The photo was taken after installing the thru hull 11 years ago. The coil was virtually just as clean prior to launch this year and I have never had to touch it. It just wasn't as shiny as new.
post #15 of 21 Old 08-04-2014 Thread Starter
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: keel cooling
that is pretty cool (sorry about the pun!) looking
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #16 of 21 Old 08-04-2014
Re: keel cooling
My yacht has keel cooling no external pipes just a tank in the keel it works really well have had no issues.Never gotten hot when the boat has a furry bum.A lot less hassle than a heat exchanger
Brent Swain likes this.
harmonic is offline
post #17 of 21 Old 08-04-2014
Over Hill Sailing Club
smurphny's Avatar
Re: keel cooling
Ditto here. I have the same thru-hull and spent last winter in very warm, growth-prone water. The inside of the device remained clean.
smurphny is offline
post #18 of 21 Old 08-08-2014
1974 Cal 29
Re: keel cooling
In debating my diesel re-power, I've considered some air-cooled diesels. My plan was to cool the oil for the engine. I would use the existing through-hull to let sea-water into a tube, inside which a coil of copper tubing is wound for the oil to run through. A diaphragm pump would pull water out of the other end of the tube and pump it into the exhaust pipe. The only concern is that a broken oil cooler line would lead to seawater in the wrong part of the engine!
Seafarer is offline
post #19 of 21 Old 08-08-2014
Re: keel cooling
Most transmissions are water cooled so there's no problem in cooling engine oil same way but why a 'diaphragm ' pump? go to all the trouble of bringing salt water in and cooling the exhaust and still have to deal with lots of hot air and noise. As for keel cooling, big difference between the needs of a little fridge and a 671 Jimmy.
Capt Len is online now
post #20 of 21 Old 08-12-2014
1974 Cal 29
Re: keel cooling
It's a small electric 300GPH diaphragm pump. I already have it, and figured it would be the easiest way to rig a pump, as it's just a few hose-clamps to hook up to the heat exchanger.
I'm not really sure of any electric water pump that is rated to run for days at a time....
Seafarer is offline
Cooling problems - Help please tspooner General Discussion (sailing related) 14 08-05-2013 03:56 PM
Keel cooling Old dream General Discussion (sailing related) 7 07-23-2013 07:58 AM
Cooling system wonbae Diesel 3 11-25-2010 01:48 PM
Cooling Cabin wvnutt Gear & Maintenance 22 07-16-2007 09:54 PM
Cooling Systems hearts desire Gear & Maintenance 1 05-30-2003 05:31 AM
