When Do You Reef? - Page 3 - SailNet Community
 31Likes
post #21 of 82 Old 08-25-2014
RichH's Avatar
Re: When Do You Reef?
Originally Posted by SVAuspicious View Post
Hallberg-Rassy 40. I reef on the helm, not wind speed. Wind speed varies with aspect angle but the helm angle doesn't.
With a 100% jib on the furler I reef the main every time I get weather helm consistently above 10 degrees. After the third reef in the main I furl the jib entirely and fly my staysail.
With a 135% on the furler I roll up the genoa to about 90% first and then start tucking in the main. Again, the threshold is 10 degrees of weather helm.
When things get really sporty I drop the main entirely and wrap the reefing line tails hard around the sail to reduce windage and sail on the staysail.
Yup I agree, about 10 of helm or when I can see that much of a rudder turbulence angle coming off the stern and showing the boat is skidding off to leewards ... its time to reef down a bit.
My boat is a cutter rig with the mast at nearly 50% LOA (not LOD) ... I reef 'back to front' as the combined CE is in the staysail.
RichH is online now
post #22 of 82 Old 08-25-2014
Over Hill Sailing Club
smurphny's Avatar
Yes. I have a removable inner forestay and can point much better with staysail alone on that than a partially furled jib on the forestay. It's better yet with some main up but weather helm increases significantly on my boat if heel angle gets too high.
Just for reference, I was in the English Channel once in a storm and handed off to the relief watch with guidance that "France is over there. Don't hit it. England is over there. Don't hit it either." We can make reasonable ground to windward hauling in the backstay and using the running backs with just the staysail. Sometimes not hitting anything is good enough.
Do you use the main if you have the runners engaged? Last year I installed an inner forestay with running backs to be used with the loose-footed trys'l and storm jib. I'd be afraid to chance using the main with those runners in place. A mistake/jibe could bring down the works if the boom slammed into the runners, especially in the heavy winds you'd be dealing with at the time.
smurphny is offline
post #23 of 82 Old 08-25-2014
Originally Posted by Alex W View Post
There are too many variables to tie this down to a single number.
Exactly... Discussions of this sort are primarily of 'academic' interest, is seems... :-)
I think Auspicious and killarney have it right... I generally reef when I FEEL like doing so. Sea state will often have more to do with it than wind speed, and so many other considerations such as whether it's day or night, how hard-pressed I might be to make a destination or how tired I might be, and certainly whether I'm sailing offshore, or a more protected body of water... In a boat as small as mine, beating to weather offshore, sometimes when it's time to start thinking about reefing, you're often pretty close to the point where it might also be time to consider heaving-to for a bit... :-)
Finally, what time of the year are we talking about? Most folks haven't a clue, how much 'heavier' 18 knots of air on Albemarle Sound might be in January, than it is in July...
oysterman23 likes this.
JonEisberg is offline
post #24 of 82 Old 08-25-2014 Thread Starter
casey1999's Avatar
When I posted the question, it primarily had to do with when your boat is overpowered (thus impacting rudder angle). Curious as to if larger heavier boats are able to handle higher wind speeds as oposed to a smaller lighter boat and what specific wind speeds they might handle.
christian.hess likes this.
In the beginning, there was only water...
casey1999 is offline
post #25 of 82 Old 08-25-2014
Casey, I have no idea what your boat and rig are like.
Or what your purpose in reefing is.
If you want to optimize boat speed, you reef according to the VPPs for your boat. You may be surprised to find that putting in the first reef and reducing the job at speeds as low as 15 knots can increase your effective speed, by reducing leeway and allowing the boat to stand up right.
If you can't access VPPs, you need to try different sail combinations at different wind speeds to find out what's "true" for your boat. (With whatever crew you normally sail with, as opposed to what the VPPs call for.)
Reefing? Generally, if you have to ask, you should have done so about fifteen minutes earlier. That's for comfort. Sometimes not reefing and letting the rail make a splash is great entertainment too.(G)
hellosailor is offline
post #26 of 82 Old 08-25-2014 Thread Starter
casey1999's Avatar
I do not have a VPP for my boat, although as I remember S&S designed the boat to sail fastest at a heel angle of 23.5 degree. I normally sail at about 15 degree max as single handing normally, I do not like to press the boat. I am normally well reefed (over reefed) and could normally sail at least 2 knots faster (5.5 knots as compared to 7.5 knots) by taking a reef out (and probably be at the 23.5 degree), but that is really pushing the boat and keeping me on my toes.
post #27 of 82 Old 08-25-2014
I tend to reef at 15 to 20 knots. It is more of a feel thing. If the boat feels overpowered, I will furl the Jenny. If it seems too windy, I reef when raising the main. It is easier to shake out a reef than to put one in. The boat is a Catalina 30.
I find that on most days that I reef, many others do not. I sail at a much more comfortable angle of heel and tend not to lose much , if any, boat speed.
s/v Odyssey
Catalina 30
glassdad is offline
post #28 of 82 Old 08-25-2014
Coronado 25, ten years out of Sausalito, in & outside of San Francisco Bay, in partnership with my Dad, who loved to "bury the rail", he knew better, he just liked to do it, used to make our daughters squeal & my wife dive for cover below.
I was the "referee". In the summer afternoons the stock sails would overpower the boat big time. Finally convinced my Dad to get a smaller jib & installed jiffy reefing, which was a big improvement.
When to reef? as others mentioned, when, or better yet, before the boat is overpowered, lots of variables, gut instinct. When my Dad wasn't with us, I would put the first reef in at the dock. When he was with us, it was a struggle as to when to reef.
Paul T
dabnis is offline
post #29 of 82 Old 08-25-2014
Mermaid Hunter
SVAuspicious's Avatar
Of course. They (or the staysail) wouldn't be much good otherwise.
Recognize that the runners are generally only needed upwind. You don't need them both - just the upwind one. When you tack you ease the upwind runner, tack, and take up the (new) upwind runner.
When you rig your trysail you have to take the runners into consideration so they don't foul one another.
Off the wind move the runners back forward to their parking spot and rig a preventer on the main. I've never seen a mast pump on reefed main and staysail well off the wind.
The greatest value of a trysail is to protect your main so you can make good speed after things settle down. Personally I'm a "deep reef in the main" guy. I don't have a boom crutch and I'm not strong enough to get the main off the boom and below anyway so my judgment is to reef the heck out the sails. The worst I've been in is F8 rising 9 for a couple of days in the English Channel. YMMV.
smurphny, casey1999 and SavvySalt like this.
SVAuspicious is offline
The Following User Says Thank You to SVAuspicious For This Useful Post:
smurphny (08-26-2014)
post #30 of 82 Old 08-25-2014 Thread Starter
casey1999's Avatar
Real men don't reef:
How to reef a lateen with reef points MattMcc804 General Discussion (sailing related) 9 05-06-2013 12:52 AM
When to reef? lawsonmitchell Learning to Sail 10 04-15-2011 01:37 PM
Why reef at all...? backcreeksailor Learning to Sail 53 06-12-2009 05:45 PM
To reef or not to reef, that is the question blackpearlsailing General Discussion (sailing related) 12 05-28-2008 07:46 PM
My first Reef... Stevyboy General Discussion (sailing related) 11 04-08-2008 12:45 PM
