It only took 14 years to fix... - SailNet Community
 4Likes
  • 4 Post By mstern
post #1 of 5 Old 08-29-2014 Thread Starter
mstern's Avatar
When I bought my Oday 23, the boat was on the hard for the season with the mast down. I didn't notice until the survey that the connector plugs on the deck and at the mast for the steaming light were broken.
I figured I'd have time to fix it during my first season. Well, due to a host of things, I never got around to it. That was in the summer of 2000. Over the years, I made several efforts to get the steaming light functional. I tried several times to repair the existing plugs (one on the deck right near the mast step, one on the wiring that exited near the bottom of the mast). That didn't work. One year, I had the yard lay out my mast so I could work on it prior to launch. I brought a 12v battery and spent a few hours trying to figure out where the problem was; was it the plugs themselves? the wiring? the light? As far as I could tell, it was either the plugs or the light or both (clearly, I didn't do a very good job of troubleshooting). I bought and installed new plugs, but that fix the problem, so I knew that my last real chance to fix this was to replace the steaming light itself. However, I ran out of time again, so again the mast went up and I launched with the problem unsolved.
No big deal as I rarely sail in any conditions where the light was necessary. And I lived with the guilt of not having a steaming light during those few times when I should have had it lit (NB: my other running lights work fine).
While at the Defender Spring Sale last year, I saw they had steaming lights on sale, and I bought one, thinking: "this is definitely the year that I get this bad boy working". Except, not. I spent a lot of time that spring installing a new chartplotter/depthsounder and VHF, leaving not enough time to work on the steaming light.
This spring, the stars aligned: my mast was fortuitously stored where it was easy to work on, and I was able to rather quickly and easily install the light I had purchased the year before. So now the thing will work, right? Not so fast. The "new" plugs that I had installed a few years before had become "uninstalled" over time as the exposed wiring continued to deteriorate. I have very limited free time and I like to use my "boat time" to actually sail rather than do projects, so I was thinking that once again, this may slide to next year.
But I just happened to be at a Lowe's and decided to at least buy the parts I would need to do the job. So I bought new wire, connectors and shrink tubing, threw them in my boat bag, and hoped that I would find some time.
The weather was gorgeous last evening and my wife was working, so I thought I would go to the boat after work. When I got there, I decided it was really too windy to go sailing (gust of about 20 knots), so I thought it would be a perfect opportunity to give it one more try to fix the steaming light.
I hook everything up, go to the cabin and flip the switch, then walk around to the front of the mast and cautiously look up to see if the light is lit....
Hooray! It works! Fourteen years later, I have a working steaming light!
I can't decide if I'm proud, ashamed or both...
mstern is offline
post #2 of 5 Old 08-29-2014
One of None
deniseO30's Avatar
Re: It only took 14 years to fix...
I bought a Blue seas ACR took me 3 yrs to get around to it. Best thing I ever did!
My last project!
deniseO30 is offline
post #3 of 5 Old 08-29-2014
Skipper Jer's Avatar
Mmmmm...here comes bad news Captainmeme. You used wire from Lowes in a marine environment? Me thinks it will be 14 months when you have to replace the wire due to corrosion. Enjoy it while you can.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #4 of 5 Old 08-29-2014 Thread Starter
mstern's Avatar
Hmmm. This is supposed to be wire that can be buried. That plus the fact that most of it will be covered by the tube shrink wrap will hopefully protect it. If not, then I am hoping it won't be another 14 years before I fix it again.
mstern is offline
post #5 of 5 Old 08-29-2014
Tartan 27' owner
CalebD's Avatar
At least it got fixed.
It will last as long as it lasts...
Everybody has one:
CalebD is offline
Need Help With Fix Up Fenex Gear & Maintenance 31 07-19-2014 12:57 PM
Catalina 22s Good Years Bad Years TJ8187 Boat Review and Purchase Forum 2 03-27-2012 01:58 PM
Good Years and Bad Years MooreVOLS Boat Review and Purchase Forum 7 08-26-2010 12:04 PM
your boat for 2 years, my house for 2 years wantogonow Cruising & Liveaboard Forum 0 08-27-2009 05:42 PM
