  #1
Old 05-17-2006
Nacci1 is on a distinguished road
Drilling SS tubing - installing ladder treads
I have some swim ladder treads to install. How difficult is it to drill the stainless tubing? Any tips on the drilling or riveting so I do not mess-up ladder?? Thanks!
  #2
Old 05-17-2006
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Use a sharp bit in a high speed drill and you shouldn't have any problems. Stainless steel tubing is fairly thin, so overheating isn't a big concern, but a squirt of oil wouldn't hurt. You should use a center punch to mark the hole's center, preventing spin-out. I would also tape the area first to protect the finish - just in case.
True Blue . . .
sold the Nauticat
  #3
Old 05-17-2006
Captain
paulthober is on a distinguished road
Not to start an argument, but my experience is of course a sharp drill bit, however, low rpm, considerable pressure, and cutting oil gives the best results.
  #4
Old 05-17-2006
Yes, I'd second paul's suggestions...and recommend a cobalt coated drill bit as well.
  #5
Old 05-17-2006
Irwin32 is on a distinguished road
I agree with the low speed. Once SS heats up it can get nearly impossible to drill.
You may post attachments
You may edit your posts
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
SEO by vBSEO 3.6.1
