Replacement key - SailNet Community
post #1 of 4 Old 06-01-2006 Thread Starter
Replacement key
Can anyone tell me how to get a replacement key for a 1997 Universal 18hp motor. The admiral missplaced it on Monday, besides it's not a bad idea to keep a couple of spares.
Thanks
Dave
dmurcott is offline
post #2 of 4 Old 06-01-2006
sailandoar's Avatar
Ignition/Starting key? => new switch!
I assume that the (start/ignition) switch would have to be replaced.
If there is a serial number on the switch it might be possible to contact either Universal or more likely the switch manufacturer and have a key made. More commonly, it seems that the switch is a fairly cheap(??$20-$35??) item and that finding a new key for that switch is cost/time prohibitive.
sailandoar is offline
post #3 of 4 Old 06-01-2006
Replacement Key
You may find, as is the case with my Yanmar, that all the keys are the same, at least for that engine panel.
You might want to check with Universal before replacing the switch.
chuda01 is offline
post #4 of 4 Old 06-01-2006
Local hardware store makes spares for me using a blank for a cabinet lock if you can find an old one to copy. As others have mentioned try using a dockmates key, lots of times they will work with almost anything that fits in it.
capttb is online now
Hot Water Heater Replacement sailthechesapke Gear & Maintenance 2 04-09-2013 11:46 AM
Teak Deck Replacement - Flexiteek rbaker6966 Gear & Maintenance 8 04-16-2008 11:53 PM
1977 Columbia 23 gudgeon replacement stclair@auglink.com General Discussion (sailing related) 2 03-20-2006 07:50 AM
Pull engine switch replacement Neicy Gear & Maintenance 12 09-06-2005 06:05 AM
Cutlass Bearing Replacement, 1985 Najad 343 kc_cmc Gear & Maintenance 2 12-07-2004 02:15 PM
