Onboard: Electric stove or other? - SailNet Community
 10Likes
post #1 of 61 Old 10-11-2014 Thread Starter
I have seen pictures of boats that have AC and/or electric ranges. Just curious if this is run off many batteries and solar power, or is it pretty simple to get power off your engine,be it an inboard/outboard or just an outboard? I didn't see any generators unless they were tucked away.
wallster is offline
post #2 of 61 Old 10-11-2014
re: Onboard: Electric stove or other?
These boats you are talking about...were they actually running these devices while away from the dock?
If they were, and you didn't see any generator, chances are close to 100%, they had an installed marine genset. You would need an awful lot of battery power to run anything but a very small AC unit and especially a power hungry electric stove.
I've got a 16,000 BTU AC unit on my boat. Only runs when I'm at the dock.
zeehag likes this.
Catalina 34
chuck53 is offline
post #3 of 61 Old 10-11-2014 Thread Starter
That makes sense. Yeah it was just pics of modifications people had done and they were selling the boat so I didn't see them as they were underway. Logical though that it would just be used when they are in a marina.
wallster is offline
post #4 of 61 Old 10-11-2014
One of the most inane things that boat builders do is install electric stoves.. since the inverter/battery use for such a thing is impractical it means a generator is the only way to make it work.
When you get around to spending weekends on the hook you'll know which boats have electric stoves when you hear the generators fire up at dinner time... and breakfast time.... and coffee time....
Faster is online now
post #5 of 61 Old 10-11-2014 Thread Starter
Okay, sounds good. Do you guys use something like a camping stove then?
wallster is offline
post #6 of 61 Old 10-11-2014
kenr74's Avatar
Yes, a camping stove will work fine on a small boat. Just don't store propane in the cabin, as it is an explosion hazard. On my 22 footer I do most of my cooking in the cockpit, which is where I keep a couple of the little camping propane bottles.
kenr74 is offline
post #7 of 61 Old 10-11-2014
There are different options. Some do use small camping stoves, but mostly, people use rail mounted marine grills. most are connected to small propane canisters. My boat has an installed marine oven with cooktop. While mine runs on CNG gas, most are connected to propane tanks, either mounted outboard or in dedicated, sealed propane lockers.
Catalina 34
chuck53 is offline
post #8 of 61 Old 10-11-2014
Don't call me a "senior"!
Puddin'_Tain's Avatar
Get an unpressurized alcohol stove. Much safer than propane, and cheaper to properly install. No remote tank, no dedicated locker, no tubing, no solenoid, no sniffer needed, and no ka-BOOM if any of the aforementioned components fail.
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
post #9 of 61 Old 10-12-2014
Zanshin's Avatar
I disagree with you regarding electric galleys. I didn't want explosive gas inside my cabin, so I installed an electric galley; both oven and hobs. I don't need to run the generator to cook. The inverter and 1000Ah battery bank are up to the task just fine. And when I'm on the boat I don't go to a dock more than once or twice every 6 months, I'm a liveaboard and not a weekend sailor so the energy balance has to work - and it does.
Zanshin is offline
post #10 of 61 Old 10-12-2014
The OP apparently has a 24-ft boat. Not very likely that he'll have a 1000Ah battery bank or a genset.
Origo Electric/Alcohol Stove weephee Gear & Maintenance 20 09-06-2014 10:31 PM
Big Stove vs. Camp Stove tjgault Provisioning 14 02-06-2013 02:52 AM
Induction vs electric vs alcohol stove? guitarguy56 Cruising & Liveaboard Forum 33 02-01-2013 09:43 PM
Onboard shower erdagte Living Aboard 12 06-10-2006 02:10 PM
Onboard Laptop PBzeer General Discussion (sailing related) 11 01-08-2004 04:51 AM
