Need advice for autopilot - SailNet Community
post #1 of 12 Old 10-18-2014 Thread Starter
soyuz's Avatar
I have a CS-36 T that weight about 17 000 pounds loaded, right now i have no
autopilot but i did install a caphorn windvane but so far no luck, its not working
good. I am running out of time and i need to have something to steer.
any ideas ?
S/V Grey Goose
Cs 36
home port: Gaspésie.
soyuz is offline
post #2 of 12 Old 10-18-2014
Re: Need advice for autopilot
Plenty of installation examples listed here:
https://www.google.ca/webhp?sourceid...ndvane%20setup
Suggest your review a bunch of these to try to see why yours isn't working...
Faster is offline
post #3 of 12 Old 10-18-2014 Thread Starter
soyuz's Avatar
Thanks faster, we are talking with yves to get it to work but....
i am on my way south right now and we are running out of things to try.
S/V Grey Goose
Cs 36
soyuz is offline
post #4 of 12 Old 10-18-2014
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by soyuz View Post
I have a CS-36 T that weight about 17 000 pounds loaded, right now i have no autopilot but i did install a caphorn windvane but so far no luck, its not working good. I am running out of time and i need to have something to steer.
I agree with Faster. The Cape Horn is pretty bulletproof. You should be able to get it to work. Where are you?
SVAuspicious is offline
post #5 of 12 Old 10-18-2014
Old enough to know better
Below deck auto pilot is best, but expensive and a complicated and long install. If you are looking for a quick solution, and a very durable one at that look at the CPT autopilot. CPT Autopilot Inc. They have a reputation of working on very large boats simple but can't be connected to a plotter. (but then again neither can the wind vane!) You are about the limit for the Ramarine one. I believe Mainsail has one on his, and says it works well (may be putting words in his mouth but I think that is what he said). They have a new one out and it states 16,000 pound limit, so you are over it but if you keep the sails well trimed and the helm balanced it seems it should work. I don't see auto pilot wind vane being a one or the other thing anyway. There are times such as motoring that a vane will not work well. And an autopilot will put you right into the the wind while putting up and taking down sails, not a vane's strong point.
miatapaul is offline
post #6 of 12 Old 10-18-2014
Bristol 45.5 - AiniA
I have a newish CPT autopilot. It is rugged for sure. Loaded, our boat is close to 40,000 lbs. We only use it when there is no wind and it seems up to the task. The control/sensing unit seems very sensitive to magnetic influences. The CPT uses a magnetic compass and we could not install it where the control unit for the old Raytheon unit had been - just too much magnetic stuff there - CPT mentioned a problem with throttle and gear cables. Once we moved the control unit it was fine, but you do need to fiddle.
You should be able to get the Cap Horn to work, especially with the help of Yves. We have a Monitor and our experience would suggest two areas of difficulty. One is that the boat absolutely must be balanced. For us that has meant eliminating weather helm by reducing the size of the main. We have a roller furling main and just roll in enough sail until we are balanced. Try over-reefing. If you don't need to reef, put in one. If you need one reef, put in two. Also do not have the main sheet overtightened. We can steer our boat when the Monitor is on by moving the mainsheet in and out - even a few inches will change the course. Vanes are very sensitive devices, but once you get if figured out it becomes very easy. i don't know how the Cap Horn works from the vane rudder to the wheel, but it really matters to have minimum friction. We ended up experimenting with various blocks, but now use two Harken and two Ronstan bearing blocks. There is a fair bit of tension on them and they are constantly moving. If the blocks do not turn effortlessly it becomes much harder to steer the boat.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #7 of 12 Old 10-18-2014 Thread Starter
soyuz's Avatar
I am near yarmouth nova scotia making my way south along the coast.
The problem we have with the CH is the ship, really there is no room to work on it
we are 3 guys onboard only one can fit and we are not big or fat, you need to be really
small to fit in.
S/V Grey Goose
Cs 36
soyuz is offline
post #8 of 12 Old 10-18-2014
BarryL's Avatar
any ideas ?
Hey,
What do you want the autopilot to do? Should it be able to drive the boat straight ahead in calm conditions, follow a route on your chart plotter, steer the boat downwind in large following seas, keep the going going when motoring, steer upwind?
Steering downwind with large following seas is going to be real tough. Having something to help you steer in light wind is easy....
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #9 of 12 Old 10-18-2014
I would like some advice on the same topic.
I don't have an auto pilot. my budget does not extend to wind vanes and probably not to a under deck pilot.
My Boats a C&C 35 111. Is the raymarine wheel pilot. good enough? for coastal cruising. Steer a straight while I make tea?
Reasonably reliable? Hard on battery?
Easy to fit?
Uricanejack is offline
post #10 of 12 Old 10-18-2014
We're using a RM S-1... works fine for calm motoring, straight line while hoisting/dousing sail, reasonable on smooth reaches not so well on quartering seas or lots of/variable winds.
Prefer to steer anyway while sailing so it serves us well for what we need/want.
Faster is offline
Autopilot selection advice mbsl98 Gear & Maintenance 9 05-15-2015 08:16 AM
Roberton Autopilot - Can I still use the linear drive if the autopilot does not work? sailor1dude Electronics 1 04-07-2013 06:47 PM
Need advice on ST-4000 Autopilot primerate84 Gear & Maintenance 6 07-10-2012 02:59 PM
S1 Autopilot thisisus Gear & Maintenance 2 03-06-2009 08:55 AM
autopilot? bradfalk General Discussion (sailing related) 2 10-14-2008 09:41 PM
