Old 06-15-2006
Panacea1 is on a distinguished road
Below Deck Plastic Fuel Tank Grounding Question
Does anyone know if a plastic fuel tank installed below deck needs to be grounded? I can understand why metal fuel tanks would need an attachedgrouning wire, but I'm not sure about plastic tanks.
I recently installed an all-plastic fuel cap which recommended not to attach a grounding wire. I wonder if the same is true for the gas tank.
Of course, the gas tank is not entirely all-plastic. It does include a metal fuel gauge sender and the fuel withdrawl has a metal fitting to which the fuel line connects.
Old 06-16-2006
GordMay is on a distinguished road
Each metalic or metalic plated component of the fuel fill system, that is in contact with the fuel and the fuel tank, shall be grounded
Grounded Liquid Level Gauge transmitters (senders) shall have the negative return conductor connected directly to the the DC main negative bus (which is grounded). This conductor serves as the static ground or bond conductor for the tank or fill.
Old 06-16-2006
Plastic tanks should also be grounded. IIRC they can hold a fairly substantial static charge, which can then ignite the gasoline vapors under the "right" conditions. A grounding strap eliminates this risk.
Old 06-29-2006
Partially hydrated Member
sanjuan2R is on a distinguished road
Question fuel tank grounding
Where do you attach the grounding straps to in order to get a secure grounding?
Fuel tank problems Lusk Gear & Maintenance 18 01-23-2007 05:17 PM
T 34 fuel tank removal Peltier Gear & Maintenance 1 12-19-2001 05:44 PM
Tayana 42 Fuel Tank Question jdmrussell56 Gear & Maintenance 2 07-29-2001 07:17 AM
fuel tank problems again creek Gear & Maintenance 0 03-23-2001 01:57 PM
