Wife says icebox is disgusting - SailNet Community
 8Likes
post #1 of 30 Old 11-05-2014 Thread Starter
rbyham's Avatar
See pics. Paint sounds like a solution. Anyone have a recommendation?
rbyham is offline
post #2 of 30 Old 11-05-2014
One of None
deniseO30's Avatar
Re: Wife says icebox is disgusting
Looks like mine! which sucks because I did new counter top and, well you can see the mahogany lid frame.
I have a spray can of rustoleum paint for plastic, have not tried it yet, can't seem to find it in a can for brush on. Every time I've ever sprayed something in a box the over spray got out of control.
The pink foam is in the bottom loose and adds to insulation value. It can be removed should I want to use ice instead.
My last project!
deniseO30 is offline
post #3 of 30 Old 11-05-2014
Bristol 45.5 - AiniA
Sounds like a perfectly good reason to get a new boat with a really nice ice box, or even a refrigerator.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #4 of 30 Old 11-05-2014
Barquito
Barquito's Avatar
I would think a small can of one part marine paint would do fine. Maybe if you need to touch up your cove stripe you could do that with the same can of paint.
Valiant 32
Barquito is offline
post #5 of 30 Old 11-05-2014
Chastened
Ajax_MD's Avatar
In a word, "ew".
1981 Tartan 33 #168
Ajax_MD is offline
post #6 of 30 Old 11-05-2014
One of None
deniseO30's Avatar
No amount of scrubbing and strong cleaners changed the look of the old poly plastic either.
My last project!
post #7 of 30 Old 11-05-2014
Chastened
Ajax_MD's Avatar
I hear tell that some folks have 'glassed layers of that pink or blue foam to the inside of their old icebox and painted it white.
Not sure what they painted it with though.
1981 Tartan 33 #168
Ajax_MD is offline
post #8 of 30 Old 11-05-2014
One of None
deniseO30's Avatar
I used the pink that is glassed over to build the plywood lid. solid wood lids just kept warping and did not have the insulation I wanted.
My last project!
post #9 of 30 Old 11-05-2014 Thread Starter
rbyham's Avatar
I am thinking paint for plastic and possibly add foam sheets to build up bottom. Don't really need more R value but the other complaint is it is too deep. My elevation challenged wife can't reach stuff in bottom 4 inches anyway. Will report back
rbyham is offline
post #10 of 30 Old 11-05-2014
I'd be tempted to sand it all down to clean glass and prime it, then paint with a mildew resistant bathroom paint and give that a try for a season.
Remember if you're going to glass in ordinary styrofoam insulation as shown you cannot use polyester resin.. it will dissolve the foam. You must use an epoxy. Before I made any such permanent modifications to the ice box I'd drop a piece in there (cut to fit well but leaving a clear drainage area/channel if you're using loose or un-contained ice) and try that out first. You may find you lose too much volume.
Faster is offline
My icebox(es) sailordave Gear & Maintenance 9 08-29-2012 11:14 AM
Relocating Icebox Bermuda30 General Discussion (sailing related) 5 11-18-2007 06:57 PM
Icebox to Refrigerator offline2004 Gear & Maintenance 12 01-26-2007 04:02 PM
Disgusting Head cornachio Jeanneau 7 01-23-2007 06:01 PM
Insulating an Icebox SailNet Gear and Maintenance Articles 0 07-22-2002 08:00 PM
