Blistering - Page 5 - SailNet Community
post #41 of 84 Old 10-04-2006 Thread Starter
SunnySideUp's Avatar
Thanks
Parley,
Again thanks for all the info, I'm looking to move her in the next couple of days and setting up shop to start work. I'll keep you up to date on how it is going. May the wind be to your back and the sun on your face, Good sailing to you.
Sonny.
SunnySideUp
SunnySideUp is offline
post #42 of 84 Old 10-05-2006
Definitely heed SD's advice regarding "covering up", ALL OF IT. I even went to far as to tape the tyvek suit closed at the wrists and ankles.
Parley is offline
post #43 of 84 Old 10-25-2006 Thread Starter
Cool Update
Hi everyone,
Will I have moved Sunnyside Up into a place were I can work on her with any problem from the dock master or the dry dock next door, my backyard.
She is still on her trailer but that is ok for now I can reach most of the area that need the work. I've put a canopy over her to keep out the weather.
I have started to sand her down and most of what look to blister are in fact a bad bottom-paint job. (were the paint dried with air behind it.) However there are some very big and very deep blister that are there.
In my younger days I did car body work in a paint shop. When we had this problem (thin fiberglass that would make a hole if you tried to float it out to match the rest of the car) we would reinforce and build it up from behind and then lay and new layer of glass on the front and float it out smooth to match.
My question is do you thank that will work in this case. Any thoughts
Thanks
I thank that I'm going to blog the repair work and post some picture as I go.
SunnySideUp
post #44 of 84 Old 10-26-2006
Sonny, congrats on taking the plunge. Best of luck with your project. Let us know if you post the process (I wish I had). Regarding your question, Dunno. Seems like overkill, but without really knowing the process nor the size/depth of the blister(s) nor the hull construction (cored/solid) it is impossible to address. My recommendation is to return it to its original intended construction. For me, this simply meant cutting out various size "disks" of fiberglass, wetting out, and using to bring any deep blisters back out to at least the outer most layers of original glass. I did this with the intent of my epoxy filler simply replacing the "lost" gel coat.
Parley is offline
post #45 of 84 Old 10-26-2006
I would use parley's technique and suggest that the largest disks go on first... that way, when you're sanding it fair, you're not sanding through the fibers on the larger disks and weakening the patch by doing so.
sailingdog is offline
post #46 of 84 Old 10-27-2006 Thread Starter
Question Pop
So I have sanded the foreword quarter of the starboard side, this is were some of the bigger blister are. My question is what is the best why to pop the blister without first putting a hole in the boat and second not getting the acidic fluid that is under pressure(200 psi according to West System Gel-coat Blister Diagnosis, Repair & Prevention book).
Anyway is it a grinding thing, a pock it with a sharp insterment thing, or just sand it down till the acid runs out and sprays you all over.
Thanks.
SunnySideUp
post #47 of 84 Old 10-27-2006
Scraping the blisters is often a good way to open them up and get rid of the fluid inside relatively safely. You do need to be in a Tyvek bunny suit with face mask respirator and such for complete safety. Fiberglass is nasty stuff...and you will itch for days if you're not sealed up in a bunny suit. Needless to say, gloves and such are also a necessity.
Electricity, powered grinders and sanders and high-pressure acid spray aren't a great combination in terms of safety IMHO.
post #48 of 84 Old 10-27-2006
...goes the weasel
Sonny, I popped mine with a utility knife. Luckily all mine were dry. I can only assume 1 of 2 things: 1) All blisters were due to air voids (unlikely, but possible); 2) The boat had been on the hard for almost 2 Sacramento, CA summers (we exceed 100 deg. often)(most likely). I also used the utility knife to "cut" away the blistered material. This was the method I finally ended up using. It was very easy. I was careful not to "dig in" to the substrate and pretty much let the blister decide what came off by holding the knife as close to parallel with the hull as possible. I tried a number of different methods including a dremel tool. That was pretty good, but way too easy to go deeper than necessary.
Fair sanding and following winds while you're at it.
Parley is offline
post #49 of 84 Old 10-30-2006 Thread Starter
Here is the frist blister that I poped and pilled back. Man it is big and deep. The rest are a little smaller. Sanding is going good it is the poping that will take some time.
http://www.sailnet.com/forums/attach...1&d=1162242790
SunnySideUp
post #50 of 84 Old 10-30-2006
Not good...that blister is clearly into the laminate... UGH.
