Blistering - Page 7 - SailNet Community
post #61 of 84 Old 11-01-2006
Roger that. Thanks, SD and Sailing Fool (thanks for the link). I think I'll make one as I have materials on hand.
Also, I wanted to post this link. This is a guy who rebuilds, refurbishes older boats. He's done 2 Pearson Tritons and is now delving deep into an Allied Seabreaze. He has documented each step in stunning detail complete with explainations, tools used, and copius photos. Check it out.
www.triton381.com
Parley is offline
post #62 of 84 Old 11-01-2006 Thread Starter
SunnySideUp's Avatar
sanding
it seam the more you sand the more you find. popingblister left and right.
Thanks for all the info.
Sonny.
SunnySideUp
SunnySideUp is offline
post #63 of 84 Old 11-01-2006
parley-
good site...thanks for the link.
sailingdog is offline
post #64 of 84 Old 11-01-2006
ASA and PSIA Instructor
That may work but it may also be too rigid to fair a smooth curve on a hull.
I think for $50 they provide a product that has just the right amount of flex versus firmness - I got this product reference originally form one of the local hardcore racers. It is desigend to do this exact job...
sailingfool is offline
post #65 of 84 Old 11-01-2006
I assume you have a trailer and will be doing work with it on trailer. It would be best to remove it from trailer and have it on stands,but if not it is doable on trailer but a bit harder. I did the bottom once of C25 on roller trailer and just moved boat back and forth on trailer as I worked on it. It went well but don't let anyone kid you it is labor intensive. IMHO it would be better to open blisters ASAP and let the drying process begin...Good Luck...Dave
Scott222 is offline
post #66 of 84 Old 11-03-2006 Thread Starter
Bottom paint
I know that this is into the future but I'm wondering about it now. Bottom paint after the gel-coat and what kind, hard antifouling, rosin based antifouling,fiberglass antifouling. The list just goes on. The real bad thing about all this is i want to keep the hull white, all the paints I've been looking at do not have that color. is there like a law that states you can't paint the bottom of your boat white.
Anyway just a thought.
SunnySideUp
post #67 of 84 Old 11-03-2006
There are a few anti-fouling bottom paints that are available in white. The real problem with white hull paint is that any scum or growth really shows up quite readily and looks like crap. AFAIK, there are no laws regarding the coloration of boat hulls.
The paint I've decided to give a try is CopperCoat, which is a hard-epoxy based paint that ends up being about 85% pure copper by volume when it is applied to a boat's hull. It is a multi-year paint and unlike some of the other anti-fouling paints, not adversely affected if the boat is hauled from the water.
post #68 of 84 Old 11-03-2006
SD, is this the same paint that was once called CopperPoxy and advertised to last 10+ years? It was made on the NW coast and at one time had some difficulty with EPA approval. It had about the same percentage of copper and the color was ((suprise) copper!
TXS-ALAMO is offline
post #69 of 84 Old 11-03-2006
I don't believe so...as this is an English product, and was imported from across the pond.
post #70 of 84 Old 11-03-2006
The paint you decide to use will be dependant upon 2 things: 1) where your boat is moored, and where you will be sailing, and 2) How you plan on using the boat (i.e. trailering, stay in water, trailering once in a while, etc...) The point here is if the boat will be hauled/trailered. You cannot do that with some paints. Check Practical Sailor mag. Last issue had a review of bottom paints by area. They seem to run this test every few issues and it seems to be ongoing testing. www.practical-sailor.com
Parley is offline
