Blistering - Page 8 - SailNet Community
post #71 of 84 Old 11-03-2006
What a difference one little letter makes....
For that web site, try www.yachtsurvey.com
essman is offline
post #72 of 84 Old 11-06-2006
STARBOARD!!
KeelHaulin's Avatar
Originally Posted by Sonny Oyler
Here is the frist blister that I poped and pilled back. Man it is big and deep. The rest are a little smaller. Sanding is going good it is the poping that will take some time.
Sonny-
That blister does not look super-bad (to me). You have it ground back to just beneath the 1'st layer of woven cloth (the structural glass) and if other blisters are no deeper than this you should be in fine shape. Typically strand-mat blisters dont cause major damage to the structural mat except where the strand-mat bonds to the first layer of cloth. If you look closely at the picture there is a dark edge along the interface between the mat and the cloth (along the bottom half of the circle). I'd be willing to bet that there is still some delam between the cloth and mat in this area; possibly around the top also. Try opening it up a bit further without grinding into the woven cloth to get rid of the delamination. If it goes much further than 1/2 inch from where you are now I would stop but usually it does not. Grinding out the delamination will reduce the chances of another blister forming between the mat and the structural cloth.
Also; keep washing down the hull, buy a $100 pressure washer and rinse the hull with fresh water every few days (unless you are applying epoxy). This will help the hull dry out by flushing out salt and allowing the styrene from the blisters to wash away from the open blister areas.
JMHO/HTH...
KeelHaulin is offline
post #73 of 84 Old 11-06-2006 Thread Starter
SunnySideUp's Avatar
Pictures
Here is a picture of one of the blister that I have fully grind out and faired down to 12to1. Let me know what you guys thank.
Also thank for the info KeelHaulin.
Oh by the that would be me in the Bunny-suit, I'm glad it has gotten cold here.
SunnySideUp
SunnySideUp is offline
post #74 of 84 Old 11-06-2006
That looks pretty good, but a bit uneven as it doesn't look centered... The bunny suit is important to preserve your skin and prevent the fiberglass from driving you crazy...
sailingdog is offline
post #75 of 84 Old 11-06-2006 Thread Starter
tapping
do you thank that it needs to go more left. I have been tapping the outer part of the blister to see were the blister ends and the good laminate starts back up. The blister sounds hollow and the laminate sounds solid.
SunnySideUp
post #76 of 84 Old 11-07-2006 Thread Starter
Picture repost
I'm posting these again because for some reason that went away in an early post.
SunnySideUp
post #77 of 84 Old 11-07-2006
Yes, more to the left and up... It appears that most of the grinding and beveling has been done to the right. Ideally, the beveled area should center around the original blister as much as possible.
post #78 of 84 Old 11-07-2006 Thread Starter
Yet another one
Here is another is this more of what it should look like?
Again I would like to thank everyone for all the help and info on this project.
SunnySideUp
post #79 of 84 Old 11-07-2006
Much better. Looks much more evenly beveled.
post #80 of 84 Old 11-07-2006 Thread Starter
Thanks, now I know that I'm doing it some what right. I'll fix the other one and make sure the rest are done right as will.
Again I can't thank you enough for all the help.
SunnySideUp
