06-23-2006
Marine grade plywood specifications actually limit the number of voids and faults allowed, and specify the actual thickness of each ply, etc. Depending on what you are doing, and how you are sealing the wood, exterior grade may work just fine. However, if I were buidling a boat of any significant size or upgrading the interior of a bluewater cruising boat, I would use marine plywood, as the bulkheads in many boats are structural elements, and skimping on the materials strikes me as a bit foolish when it may save your life later on.
