Blogs
User Name
Old 06-22-2006
Bill Z Bill Z is offline
Bill Z is on a distinguished road
Question Ericson 35-3 hull to keel joint
I'm looking to purchase a 1988 35-3. The boat is in very good condition except i noticed a gap on the trailing edge of the keel to hull joint. I can see light between the two and it extends about 5 inches in from the trailing edge.
Any thoughts???
Old 06-22-2006
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Bill, if you are unfamiliar with keel issues this is the time to spend a couple hundred bucks on a surveyor. I don't know the Ericson but have never heard of being able to see daylight unless the keel was dropping, i.e. if a keel bolt had come loose or the support it was tied into had dropped. Could be nothing, could just need caulking, could just be the way that mold and keel fit. Could be damage from a grounding, which pushed the keel back and up and crushed in the hull in that area.
Could be a "RUN AWAY!" warning. Time to have a surveyor examine all the keel fittings to be sure.
Old 06-22-2006
Thanks for the input! I have a suvey scheduled.
Display Modes
vB code is On
Ericson 35-3 hull to keel joint Bill Z Ericson 5 01-09-2007 12:07 PM
A new catalina 36? paul-e Buying a Boat 32 09-21-2001 05:26 PM
Glassing hull GreenEarth General Discussion (sailing related) 9 07-02-2001 05:13 PM
Hull moisture MIKEHARTMN Buying a Boat 4 05-25-2001 05:35 PM
Hull transducers BenDaniels General Discussion (sailing related) 0 02-22-2001 09:12 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
