Proper mast rake - Page 2 - SailNet Community
post #11 of 19 Old 06-28-2006
My j/24 racing buddy in annapolis just reduced his rake slightly, which reduces tension on the headstay. This in turn allowed his jib to have a better shape, and it must have worked - he won the 2nd race saturday.
Mike
pluscard is offline
post #12 of 19 Old 06-28-2006
On the hard
CharlieCobra's Avatar
I used 6 degrees of rake on mine. She seems to like it.
CharlieCobra is offline
post #13 of 19 Old 06-28-2006
Both mast bend and mast rake will tighten up the headstay and make the sail more powerful, by allowing it to have a deeper draft.
sailingdog is offline
post #14 of 19 Old 06-28-2006
Moderator
Jeff_H's Avatar
For what it is worth, depending on the design of the boat neither mastbend nor rake automatically means greater forestay tension. Prebend can be induced into a spar with high amounts of shroud tension, or with babystay tension on a masthead rig, which in terms slightly shortens the length of the mast loosening the forestay. By the same token, a mast can be further raked by loosening the forestay.
Jeff_H is online now
post #15 of 19 Old 06-28-2006 Thread Starter
Originally Posted by infonote
On boats like H-Boats, having the mast lean forward is done. I agree that it improves performance.
How does it improve performance? Where is the mast in relation to the keel?
noscreenname is offline
post #16 of 19 Old 06-28-2006 Thread Starter
Originally Posted by Jeff_H
Historically, boats of that era were typically designed with a 1/4" of rake per foot, and then tuned to provide a balanced helm. 5.5 meter class boats of that era (which is what the Sabre was) typically began life without a huge amount of rake or bend in lighter going and a bit more in heavier winds which seems counter intuitive but more backstay pressure meant more headstay pressure.
7/8 rig Jeff...with this type of rig you need either a Jumper strut, swept back spreaders, or running backstays only then can you achieve proper headstay tension. Otherwise as soon as you start to get proper headstay tension on a Sabre, without a jumper strut or Runners you start to bow the mast forward just above the lowers.
Try to take it back with the backstay and you induce lots of light air killing, flattening, in the upper part of the mast.
We're still learning, but I'm leaning towards 6-8" Rake 1-3" bend and runners to take the sag out off the head stay when the wind pipes up.
post #17 of 19 Old 06-28-2006
JeffH... I probably should have said can, not will. Depending on the design of the boat.
post #18 of 19 Old 06-28-2006 Thread Starter
Exactly!.... back stay tension doesnt always mean head stay tension especially on a 7/8 rig.
S/D....."Both mast bend and mast rake will tighten up the head stay and make the sail more powerful, by allowing it to have a deeper draft." .... This comment doesn't make much sense in my case.
post #19 of 19 Old 06-29-2006
Partially hydrated Member
Question Mast rake
Jeff,
What mast rake would you recommend for a Ranger 37 ? I intend to try to race it next season when I learn a bit more about how to handle the spinnaker. but this season will be learning , learning, & more learning. Thanks.
sanjuan2R is offline
Electrolysis / Keel stepped mast WillS Gear & Maintenance 14 06-27-2006 01:45 PM
Mast Rake for Cape Dory 30 Bob Ohler General Discussion (sailing related) 3 08-08-2001 09:03 AM
Spartite 2000 mast wedge replacement system - need info Capt.CarroleWard Gear & Maintenance 2 05-30-2001 06:01 PM
Changing mast from keel to deck step vickers41 General Discussion (sailing related) 1 04-10-2001 02:08 PM
Ericson- Mast Compression Problem Jeff_H Gear & Maintenance 2 12-31-2000 09:30 PM
