1. NEVER put regular toilet paper in the bowl as it clogs the septic pipes and makes a REALLY nasty mess. If you are at the dock, have your guests use the marina restrooms.
2. Make sure your surveyor checks carefully for termites, so that your Mom doesn't find them later while cleaning out the drawers.
3. Don't blow out your fuses on your second night aboard by plugging too many things into the outlets (and if you do, don't blame it on your boyfriend since it wasn't his fault and he is the one who will buy you new fuses and install them to boot!)
4. Don't drop a panel of your deck in the water when you remove it to scrub it with bleach (and if you do, make sure to hit the deck, grab a corner and call for help - you have 10 seconds before it sinks). A tip: if your bilge
pump works you don't need to remove the deck at all, the water will go into the engine compartment and the
pump will take care of the rest.
5. Make friends with your neighbors as they will have the phone #s of the repair people to fix the above mistakes and they will know what parts you need if you decide to do it yourself.
5. Do wake up early and enjoy the quiet morning tranquility.
6. Do add to this thread to help out this learning Lady Pirate!
