Coffee: Best/Simplest method - SailNet Community
Blogs
Old 07-03-2006
pluscard is on a distinguished road
I have a J/24, and I don't have much in the cabin for cruising... but I'd really like to be able to make coffee on the boat. I saw a guy heat water once with sterno and a gimbal, and then make instant... it was so nice to have coffee on the water.
I have a battery, but no inverter, and no water storage at the moment... what options do I have?
Also, I'm a bit picky about my coffee, so even if it's more work, I'd go extra steps to have good coffee.
Mike Luddy
South Hill, Va
Old 07-03-2006
astraeus's Avatar
WAFI
astraeus is on a distinguished road
I use a coffee pot from a camping supply store and heat it on my alcohol stove. You can use regular ground coffee and it sure beats instant!
Old 07-03-2006
Surfesq's Avatar
Surfesq is on a distinguished road
Gentleman, Gentleman....We are Yachtsmen remember that. Boil water and use a French Press. It's the better than you will get anywhere!
Old 07-03-2006
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Mike,Here's another vote for a french press. Simple and makes great coffee. If you don't have much of a galley, buy one of those single butane burners that chefs use on buffet lines. For water, buy a gallon of spring water at a grocery store for a buck and you're set.Do you sail on Buggs Island? My parents had an antiques shop in South Hill for years and had a house on the lake. Boydton was their mailing address. Small world, huh?
Old 07-03-2006
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
The single burner butane stove is a good idea. However you decide to make the coffee though, get a good thermos and make enough to last you. Then you only have to heat the water once.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
Music on the Wind -
Old 07-03-2006
Yes, I sail on Buggs Island Lake, also known as Kerr Lake on the NC side. Buying a gallon of spring water is excellent - I'll get several and stow them, along with the single burner stove.
Thanks for all the replies!
Mike
Old 07-04-2006
Jeff_H's Avatar
Super Moderator
I have used an Italian expresso pot for decades now. These are the pots where you put the water in the bottom, the coffee in a strainer in the middle and the coffee rises to a chamber in the top. It makes super coffee quite quickly. I am a big fan of an Origo non pressurized alcohol stove for a boat like the J-24 which does not have the bilge blower or the explosion proof switches that are supposed to be aboard if you are using a heavier than air combustible gas.
Old 07-04-2006
I'd vote for the French Press or the modern day equivalent.. The Aeropress is pretty cool too. http://aerobie.com/Products/aeropress_story.htm
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
