This boat is definitely not one of ours (Whitehall Rowing and Sail). It is a smooth skinned hull while ours are laptrake. It's buoyancy chambers are much smaller and the centerboard well is entirely different. The exterior hull shape is also quite different. The cut away keel appears to have been done in order to ad an inboard motor. The woodwork is quite a bit chunkier, appears to be varnished mahogany rather than oiled teak and there are no custom bronze castings showing our company name or the model name.
Does it have a hull number embedded in the gelcoat finish or any other type of identifying marks? If not, then I would say that the boat was probably built by an amateur builder who may have built one or two.
Visit our web site to view our boats at
www.whitehallrow.com. You will notice that the hulls have a high, upswept stern and high bow.
Best regards,
Marie Hutchinson
