Blogs
User Name
Old 07-11-2006
aruggiero aruggiero is offline
aruggiero is on a distinguished road
Deck Prism
We recently bought an old boat that we are currently restoring. In the cockpit there was a big hole that had a piece of plywood screwed on over it. We decided to put a deck prism there to fill the hole and also give more light at the nav station. We didn't receive any instructions with it. I was wondering if anyone knows what is the best type of sealant to use to attach the prism to the trim ring?
Old 07-11-2006
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
5200 is a good choice if it is a glass deck prism and metal or wood trim ring. 5200 will attack some plastics...
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 07-11-2006
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
No...use silicon. Water WILL eventually find its' way back in and you will appreciate being able to get the dang thing back out and re-bed it in 20 minutes rather than hours. I have 6 on my boat and the last guy used 5200...every one has silicone now.
Old 07-11-2006
BTW, is the deck on your boat cored? If so, does the hole that is drilled through the deck have the core removed around the edges and replaced with thickened epoxy??
Silicone can be a good sealant, but it has to be installed properly. How does the trim ring attach to the deck? What you might want to do is use 5200 to attach the prism to the trim ring, but use silicone to bed the prism.
Silicone is not really a good sealant. It really works best under compression, more as a gasket than a sealant. None of the silicones on the market have very strong adhesion properties...and as such, aren't usually all that suitable, unless allowed to form a fairly thick gasket and then held under compression.
Old 07-12-2006
Omatako's Avatar
Omatako Omatako is offline
Omatako is on a distinguished road
One major issue with silicon is that you should only use it in areas that you NEVER want to paint again. Once you've had silicon on a surface, even the wiped areas after you have cleaned may look clean but will shed paint like ducks shed water.
I would use a mastik type of non-hardening sealant and make sure that the fasteners are really good.
Old 07-12-2006
It is a cored deck. We haven't filled it with epoxy yet but we plan to - the plywoood that is there is screwed in and it doesn't appear to be sealed. The trim ring screws on with #6 screws. The prism is glass and very, very heavy.
Thanks for your responses!
Old 07-12-2006
Don't forget to drill the holes for the screws oversized and fill them with thickened epoxy too. Also, best to throughbolt the deck ring, rather than relying on screws to hold it in place.
Display Modes
vB code is On
Hammock mounting on sailboat deck Panacea1 General Discussion (sailing related) 22 05-13-2007 07:33 PM
Deck reconditioning for my Tartan 30 Dan Desjardins Gear & Maintenance 2 07-03-2006 12:20 PM
Below Deck Plastic Fuel Tank Grounding Question Panacea1 General Discussion (sailing related) 3 06-29-2006 07:15 PM
Corecell foam sanwiched deck rbh1515 General Discussion (sailing related) 1 06-07-2001 08:37 AM
Changing mast from keel to deck step vickers41 General Discussion (sailing related) 1 04-10-2001 02:08 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
