keel depth - SailNet Community
 2Likes
  • 1 Post By capta
  • 1 Post By RichH
post #1 of 8 Old 01-11-2015 Thread Starter
keel depth
Question for those who have sailed the Bahamas. I am looking for a boat 35-38' to use to cruise florida and the bahamas. I know that shoal Draft would be optimum but will I be sorry if I get a boat with a 6' draft?
desert sailor is offline
post #2 of 8 Old 01-11-2015
Master Mariner
capta's Avatar
Re: keel depth
I've sailed the Bahamas extensively with a 9' draft; the back door into Nassau being the only place we actually touched bottom (we couldn't get under the bridge). It requires good route planning, attention and a good supply of Rolaids, but it was doable.
With 6' you shouldn't have too many problems, but do stock up on Rolaids. If the water is still as clear as it used to be, you can think you are about to run aground in 60' of water, in some places. I'd guess the cruising guides have probably improved a bit since the 70's.
christian.hess likes this.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #3 of 8 Old 01-11-2015
merit 25 solo "er"
christian.hess's Avatar
Re: keel depth
man I still have memories as a kid cruising the bahamas and having that exact same feeling of running aground EVERYWHERE...however we never did...I also remember the crystal clear water and seeing many a bonefish and shark way down on the bottom running around the grass and stuff
Islander 36 no longer for sale...its MINE!
Planning maiden cruise for November-December 2015 to Panama Canal! The planning begins!!!
christian.hess is offline
post #4 of 8 Old 01-11-2015
Yorksailor's Avatar
Location: Tahiti and heading for Tonga and New Zealand.
Re: keel depth
Like Capta I have sailed the Bahamas with a deep keel...8ft...but it was a lot easier and less anxiety provoking in a centerboard boat.
There are a lot of good boats with centerboards or keel boats with 5 to 6ft drafts especially if you are looking at older boats.
The older Sparkman & Stevens designed Tartans are good boats. I have been off-shore in a Tartan 34 centerboard boat and she performed very well.
Phil
Yorksailor is offline
post #5 of 8 Old 01-12-2015
denverd0n's Avatar
Re: keel depth
Will you be sorry? Probably not. You can still go most places with a 6' draft. It's a matter of trade-offs. With that draft there will be some places that you cannot go, and other places where you will have to be much more careful about the state of the tide and so forth.
For myself, living on the west coast of Florida and knowing that the great majority of my sailing is going to be here, in the Keys, and in the Bahamas (all shallow areas), I would not want a boat with more than 5' of draft. There are plenty of good boats out there that fit the bill, and that will be perfectly adequate for taking anywhere that I will ever want to go. For my circumstances, I just cannot see any reason to buy a boat with a deeper draft.
For you, though, things might be different. If the Bahamas are just a starting point, and the plan is to spend most of your time in areas with deeper water, then a deeper draft might make a great deal more sense. It's really just a personal choice as far as the trade-offs.
Good luck.
denverd0n is offline
post #6 of 8 Old 01-12-2015
RichH's Avatar
Re: keel depth
6ft. draft is suitable and adequate for 95% of the Bahamas. Especially, using a chart plotter loaded with 'Explorer Charts' or using the paper Explorer chartbooks will keep you in adequate depths.
You simply will get 'used to' sailing with a few inches of water under your keel and it will become second nature to you. You'll soon become very aware and cautionary of spring tide low tides or will wait for the proper tidal height to pass through the 'real shallow' areas. Most of the sailing there is 'visual' and you'll soon learn to correctly 'read the water'; plus, the water there is quite clear.
6ft draft in the Bahamas .... not a problem.
RichH is offline
post #7 of 8 Old 01-12-2015
Re: keel depth
Phil
When you say older Tatrtans, 70s -80's? Maybe a dumb question, I'm new here and trying to learn.
thezzzone is offline
The Following User Says Thank You to thezzzone For This Useful Post:
FSMike (01-12-2015)
post #8 of 8 Old 01-12-2015
Re: keel depth
I think centerboard can a blessing at times. My 1979 Bristol 35.5 is 3'8" with board up. Great for shallow slips and rivers.
endoit is offline
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 09:43 PM
Draft minus keel depth on Cape Dory 28? Nonkjo Boat Review and Purchase Forum 16 03-21-2012 02:29 PM
Digi-Depth 99 Depth Sounder sdumo Electronics 0 12-04-2011 02:06 PM
Good Depth keel for Barnegat Bay bkupmstr General Discussion (sailing related) 4 03-21-2009 07:15 AM
Shoal draft keel versus regular fin keel GBurton Boat Review and Purchase Forum 21 08-17-2007 11:33 PM
