Hydrogen sulfide removial from glass - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Old 03-01-2015
warren5421 is on a distinguished road
I have a pair of antique globs in my head that have trued black when light is off from a bad water heater. Color comes through when light is on. Anyone know what I can use to clean them. Had an old timer tell me to get some battery acid and soak them. I have tried several paint and varnish removers, nothing is working. The brass polished right up from being black. The wife has let me know if I had fixed the water heater the globs 0would be ok still.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 03-01-2015
desert rat is on a distinguished road
Re: Hydrogen sulfide removial from glass
try hydrogen peroxide.
Zen is a matter of recognizing reality.
  #3
Old 03-01-2015
krisscross's Avatar
krisscross is on a distinguished road
Yes, hydrogen peroxide might work, but I'm afraid the 3% stuff from a drugstore might be too weak. But it is worth a try - has to be a good soaking, and you need to remove all traces of solvent from it first.
Plato
  #4
Old 03-02-2015
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
You mean antique globes on your light fixtures try a paste mixed from vinegar and flour let it sit until dry then wash off with plenty of water it takes patina off things quite well and just an FYI hydrogen sulfide is a deadly sewer gas
Illegitimus Non Tatum Carborundum.
  #5
Old 03-02-2015
RichH's Avatar
RichH will become famous soon enough
If you know someone who wears dentures ..... Lay the globes horizontally into a ceramic bowl filled to the top of and covering the globes with water, then put four to six 'denture tablets' into the waters, let soak for several days; the 'fizzing' action from the denture tablets should clean off the micro-soot that's penetrated into the surface of the glass.
  #6
Old 03-02-2015
Old enough to know better
miatapaul is on a distinguished road
I have had good luck cleaning antique glass with borax, very gentle, I would try soaking it in a solution of 20 mule team and water first as it is quite gentile. I would not use battery acid that will likely destroy them. Even vinegar may etch them if left on too long. I believe sulfuric acid (battery acid) is used for etching glass.
Most importantly how was this caused by a water heater? If you have an unvented propane water heater just pitch it not worth fixing as it will kill you. What kind of boat is it? Seems a lot of the Canadian boats used the propane heaters even though on most of them it says "not for installation on a boat." Never could figure out how having an unvented flame in a water heater was acceptable. They do provide nice hot water when on the hook, but could well kill you with a nice warm shower to send you out.
  #7
Old 03-02-2015
newhaul's Avatar
islander bahama 24
Another idea is oxalic acid ( bar keepers friend) many uses on a boat and epa said safe for the environment
Tags
hotwater heater , rotten eggs
You may post attachments
You may edit your posts
How much hydrogen peroxide to sanitize? pdqaltair Gear & Maintenance 13 10-01-2014 09:44 PM
hydrogen peroxide tip lajimo Gear & Maintenance 5 09-23-2012 12:17 PM
Do propane sniffers detect hydrogen? extremo Gear & Maintenance 2 05-20-2012 09:23 PM
salt, water, solar = hydrogen! deniseO30 Gear & Maintenance 44 03-21-2012 12:01 AM
New Glass 2 sailor1105 Gear & Maintenance 0 12-31-2006 12:38 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
