Morgan 41 Out Island - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Like Tree16Likes
Old 2 Weeks Ago
khammett is on a distinguished road
So I just found this video.....
This looks like a good boat. My question is, what are these sailboats mostly good for? Like liveaboarding, coastal cruising, bluewater offshore passage making? How much would one of these typically cost?
Here's the specs that were on the video...
"So, we have now consummated the deal on our new(er) sailboat - a 1978 41 foot Morgan Out Island yacht. She is a really roomy sailboat with a center cockpit and two heads. She has a Volvo Penta turbo diesel in her, and will make 7.5 knots all day long. Although she needs a bit of TLC, she has solid underpinnings and will be a great retirement sailboat for us. Here are her specifications per Jack Hornor :
Length Overall 41’ 3"
Waterline Length 34’ 0"
Maximum Beam 13’ 10"
Maximum Draft 4’ 2"
Displacement/Weight 27,000 lbs
Fuel Capacity 140 Gallons
Water Capacity 170 Gallons
Sail Area 100%
Fore triangle 792 Sq ft.
As with most Morgan OI sailboats of this era, she appears to have had the port water tank replaced with a smaller tank. The stock tanks developed leaks over time, and they were too large (138 gallons) to remove and replace through the companionway. They were normally replaced with smaller tanks, which left additional storage for other things. Because we would prefer the additional water storage, we will probably ad additional tankage.
She is a full (shoal) keel design, and at 13.5 tons, is considered to be a heavy displacement yacht. Because of this, she has a steady way about her in seas. At this point we have only had her out on a sea trial for a few hours, but we had enough wind to raise her sails and head into the Pacific, and we were impressed with her sailing ability and comfort. As with all full keel designs, she does not go to windward as well as fin keep sailboats, or so we are told, but she does well enough. We're not looking for a racing boat, but we are looking for a comfortable boat to sail the world aboard, and I believe that we have found just that."
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 2 Weeks Ago
Jeff_H's Avatar
Moderator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
Re: Morgan 41 Out Island
Morgan OI 41's were made for many years and in many variations, under several company ownerships. They vary very widely in specification and with wild extremes in build quality. There were a variety of rigs, and interior layouts, and were variations in the keel from the original very full keel, to cut away, and fin keel versions. There were huge variations in displacement and ballast ratios, sail area, and tankage.
Morgan OI 41's make reasonably good and inexpensive live-aboards, mediocre coastal cruisers, but one really would need a lot of work to make into a distance offshore cruiser.
They are notorious for hull to deck joint failures (at least on the ones which were glued together with 5200 and almost no fastenings like the one I helped repair when I worked at Direcktors Yachts). Its hard to know when the quality changes occurred since some of the boats for private owners were better built at the same time and along side of boats going into the charter fleets, which were purposefully built to a really poor specification (skip tabbing, minimal hardware, some deck hardware of mediocre quality, undersized and attached to deck with self tapping screws, Formica over non-marine plywood bulkheads, and so on) in order to save money. Some of the private owner versions had nice interior finishes with teak or mahogany plywood bulkheads and teak or mahogany trimmed 'Herreshoff style" interiors.
As a broad generality, compared to other designs of their era, let alone modern designs, they are mediocre sailors, reaching well in a breeze, but not so great upwind or in light or heavy air. That said, some versions sailed considerably better than their reputation would suggest. They tend to have a very rolly and uncomfortable motion.
T37Chef likes this.
  #3
Old 2 Weeks Ago
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy will become famous soon enough
The 41 O.I. is an excellent live aboard boat, it sails very well except when really tight on the wind. I own a 33 O.I. and have sailed up to 10.1 MPH with 15 to 20 MPH winds on broad reach. The boat rarely heels more than 15 degrees on a beam reach with 20 MPH winds.
There is an enormous amount of interior and storage space in both the 33 and 41 O.I., more than many boats that measure much longer. Storage space is awesome, the both the fuel and water capacities are more than many larger boats.
Some models of the 41 do not have the companion way leading to the aft cabin, and you have to go into that cabin from the cockpit entrance, which can be somewhat inconvenient in bad weather.
As stated by Jeff, there is an issue where the hull is joined to the cabin top, often resulting in leakage. This can be repaired, but it is a PITA. I have to repair mine next month. The boat is quite heavy for it's size, which accounts for it's superior ride. It slices through heavy seas while other similar sized boats are bouncing around like a cork in a hurricane.
The only reason I did not opt for the 41 is that at that stage, I didn't think I would be able to single hand the boat. Now that I have considerably more experience, I believe I could single hand sail this boat very easily.
As for the cost, it will vary substantially, depending on condition and what the current owner(s) feel they can sell it for. A bit of internet research will help determine the boat's worth.
Also, when you find the one you want, have it surveyed. This will provide you with a portrait of what repairs you will have to make to get the boat in seaworthy condition, money that should be subtracted from the sellers asking price. I've seen them for as little as $30,000 and as much as $114,000. The $114,000 boat was way overpriced.
Good luck,
Gary
tomperanteau likes this.
  #4
Old 2 Weeks Ago
T37Chef's Avatar
T37Chef will become famous soon enough
No way G Stud, I know the 33 OI well, 10 SOG maybe in Hell Gate but that boat cannot do 10 knots hull speed...simply cannot. They do motor well.
Cheers,
Shawn & the crew of S/V Windgeist
1982 Tartan 37 CB - Hull #358
  #5
Old 2 Weeks Ago
Put those peepers on, old man - I said 10.1 MPH - not knots. That translates to 8.68976 knots - still damned fast. And, yes, that was speed over ground with a dead slack tide just off Pooles Island. Winds that day put me on a broad reach, woofing at 15 to 20 mph. We flew down the bay that day, passing nearly every sailboat in sight, and several barges pushed and towed by tugs.
I figured there would be a skeptic or two, therefore I shot photo of the GPS when we were clipping right along.
Shawn, anytime you wanna try out my old tub of a boat, you're more than welcome aboard. I'll even supply the food and booze - how's that for a deal?
Gary
  #6
Old 2 Weeks Ago
T37Chef's Avatar
I grew up sailing on my best friends (parents) OI33, you are one heck of a sailor my friend! 33 x 13 beam = and 10.1 mph or 8.6 I still don't believe it sorry. Comfortable live aboard boats but they are not one thing for sure, fast. Hell...if my boat hits 8 knts I am surprised and thrilled! ;-)
Cheers,
  #7
Old 2 Weeks Ago
Shawn, I frequently hit 7.5 to 8.5 MPH on days when the wind is averaging 15 to 30. I nailed a 9 once, but that was in 45 MPH winds during a thunder storm and I was trying to run from the storm. I got nailed above mid channel with hail and torrents of rain, I was running full sails, and I thought the rigging would blow apart. Those cables were akin to banjo strings at that point. I finally heaved too and waited a couple hours for the nasties to go away
Of course, fast is a relative term when sailing. I was an official for a couple years with the APBA (American Power Boat Association) and spent lots of time in infield during races with various class of hydroplanes, Jersey skiffs, etc... Got to sit in the cockpit of the Miss Budweiser once. Thank God he didn't take off while I was there. That thing screamed at incredible speeds and ironically, the Budweiser team lost as many races as they won. I forgot what the actual speeds were, but I'm thinkin they topped out at about 165 MPH on the straitaways.
I see the Lightnings and Stars race every Thursday during the summer at Havre de Grace. They really look like they're screaming along, but in reality, none ever get above about 8 MPH at best. So, I guess things can be a bit deceptive.
So, that offer still stands, Shawn. The bar and the freezer are both fully stocked all the time. I'll sit back and sip Margarettas while you trim the boat and sail her. As for Morgans being slower than sailboats of similar size, I think that's just an old wives tale that never had any validity. Again, I think it's perception because of the way the boat handles. It never really heels beyond 8 to 15 degrees on a 20 MPH wind, it's pretty much impossible to bury the rails, and the ride is real smooth even in nasty weather.
Cheers,
Gary
All the best,
Gary
  #8
Old 2 Weeks Ago
capta's Avatar
Master Mariner
capta is on a distinguished road
I have sailed many of these boats when they were the popular bareboats in the VI. Honestly, it is a motorsailor, with a 4.5 to 5 foot draft, it just isn't going to go well to windward, hence your big Volvo turbo. Obviously off the wind they can move pretty well, especially the ones with the taller rigs.
They do well in the Bahamas with their shallow draft and the sheltered water sailing, but interisland in the Caribbean in 15 to 25 knot trades, you are going to take a beating.
One delivery from Great Inagua to St. T. (about 600 miles), I double reefed the main, cranked up the engine and slammed my way east into normal tradewind seas. It was a rough voyage and we managed w/o any problems, but the boat was brand new (4 months). Without much longitudinal reinforcement it worked a great deal, though.
As mentioned by others, they do roll their guts out in an anchorage, but if you plan to be in marinas it would be OK.
If you are considering this boat as a Caribbean cruiser and possibly beyond, there are many boats of more modern design available, that are much better sailboats with better layouts.
facebook.com/svskippingstone
  #9
Old 2 Weeks Ago
T37Chef's Avatar
You're a damn good sailor than G and must have some sweet sails on that boat! ;-)
Cheers, I sail me boat...hopefully next week but I digress into thread drift...sorry OP
Cheers,
  #10
Old 2 Weeks Ago
capta's Avatar
Master Mariner
Gary
I really don't want to rain on your high speed here, but every now and then a GPS will give a really high max speed for no apparent reason. Perhaps it's during a particularly violent pitch or going over a wake, or perhaps during a tack.
Mine has given me a high speed of 18, 23 and even 36 once (in some pretty crappy weather) which I know for a fact my boat isn't doing, unless the GPS is taking the rotational speed of the earth into account.
Like every other bit of modern day electronics, sometimes a bit of skepticism may be called for.
Of course, with 2.5 to 4 knots of current, 10 mph isn't that off the mark.
Just out of curiosity, why is your GPS reading mph? Were you doing a ditch trip?
You may post attachments
You may edit your posts
Morgan 33 out island sck5 Boat Review and Purchase Forum 9 12-30-2011 03:56 PM
Morgan Out Island for Sale Linda Clinton General Discussion (sailing related) 3 04-20-2009 06:23 PM
Morgan 36 Out Island Sloop jacktargypsy Boat Review and Purchase Forum 2 01-28-2006 04:37 AM
Morgan Out Island Need feedback Yflyer555 Cruising & Liveaboard Forum 4 06-20-2001 12:34 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
