8 plait dock lines - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Old 1 Week Ago
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
8 plait dock lines
Has anyone made dock lines from 8-plait nylon. I have a considerable length of the stuff and need new dock lines. It seems quite soft, does it chafe more easily that double braid or three strand?
Heading back to Lake Ontario for this summer. Relatively few stops along the way from Grenada. Martinique, Guadeloupe, St. Martin (must have something to do with the French food), then Bermuda, New England and up the Hudson/Erie Canal. We were going to go via Newfoundland and Labrador but June remembered that one of the kids is getting married this summer - details, details!
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 1 Week Ago
Stumble is on a distinguished road
Re: 8 plait dock lines
I have been using it for years on our 58'. Works great, and chaff seems minimal.
Greg Rubin
Attorney
  #3
Old 1 Week Ago
ggray is on a distinguished road
That is what came on our boat.
It did fine, but for a given diameter, I believe it is not as strong. It's not as compact, so not as much fiber there, per unit area.
  #4
Old 1 Week Ago
Senior in age only
HankOnthewater is on a distinguished road
Chafe is ONLY caused by contact with other stuff between the 2 attachment points, and then when it does, chafe depends to some degree on the type of rope is used. I would say the construction of a rope has very little to do with that.
I have to add that there are some double braid ropes out these where the outer ‘mantle’ is for protection and the inner core provides the strength.
Back to your 8 plait: Go for it!, it remains subtle, although it is harder to splice than common 3 strand.
When you want to splice your 8-plait, here a good link how to do that by Sampson http://www.samsonrope.com/Documents/Splice%20Instructions/8Strand_C1_Eye%20Splice_JUL2012_WEB.pdf[/URL]
Regarding strength: indeed volume of rope material per linear ft or mt reflects the strength, but in my experience the difference is little (ie less than 10%) when using quality ropes. Just check some stats on-line and see if the rope you have is strong enough. Note that nylon can absorb big shocks far better than any other kind of rope. If the rope is too heavy/thick/strong it will NOT stretch much anymore and it becomes also more difficult to handle and stow.
In my case (10-11 ton 34 ft ferro boat) my anchor line is 16 mm nylon 3 strand, my docking lines are 14 mm double braid, outer braid polyester, inner that of nylon. But when I can off-load my 3 strand, I like to replace that with Nylon 16mm 8 plait, that will remain softer and easier to stow than the 3 strand.
Wishing all a safe port ahead, sunny skies above, gentle winds behind, clear water deeper than your keel below. And when on land in the bush, replace the 'clear water....' with 'firm ground'
  #5
Old 1 Week Ago
pdqaltair's Avatar
pdqaltair is on a distinguished road
No.
Virtually all double braid dock lines and polyester yacht braid is balanced constructions, where exactly 50% of the strength comes from the cover and 50% from the core. A careful examination of splicing technique makes it clear why this is so, and I have testing of numerous brands that support this.
As for abrasion, it is generally in this order, best to worst. I've done testing on this too. The rougher the surface, the more this is true, since yarn snagging becomes a big factor.
1. 3-strand
2. Double braid
3. Single braid/plait
If you want to avoid abrasion, add chafe guards, think about the run, reduce movement under load, and consider MaxiJacket where chafe guards don't fit (reduces wear about 5-10x).
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
  #6
Old 1 Week Ago
jackdale's Avatar
jackdale will become famous soon enough
I used them for many years in the boat on which we taught Yachtmaster Offshore. I quite liked them. I especially liked the fact that they had no eye splices; they could be adjusted at the boat cleat.
ISPA Yachtmaster Offshore Instructor Evaluator
  #7
Old 1 Week Ago
Capt Len is on a distinguished road
An older type gaffer can always use just about any and all rope that comes it's way. I found that the inflatable life rafts use a bunch of single braid line which is replaced unused when the raft is repacked and recertified.(I was carrying passengers) All this good stuff goes in the dumpster unless you drop into the shop and ask for it. Varying sizes and price is right. Never tried to splice it. Just butane back splice.
  #8
Old 1 Week Ago
Omatako's Avatar
Omatako will become famous soon enough
Braided dock lines appear to work OK for these guys
In fact I was coincidentally at the wharf this morning (from my ferry) and the Queen Victoria was docking - they also use braided dock lines.
My resistance to them? They cost too much. I use 16mm single braided line which has a shock-absorber inserted into the line. Also cuts abrasion down considerably because the line stretches in an area away from the fairlead. Looks something like this (mine have the shock-absorber further from the spliced loop):
Arthur C. Clarke
You may post attachments
You may edit your posts
Take your dock lines or leave them? Cruisingdad General Discussion (sailing related) 42 08-29-2013 01:53 PM
Size & Type: Dock lines vs. Mooring lines JordanH Gear & Maintenance 23 05-19-2011 10:29 PM
Dock lines my900ss General Discussion (sailing related) 12 10-23-2010 12:02 AM
Sizing of Dock Lines... MedSailor Gear & Maintenance 15 07-17-2009 12:42 AM
Determining Dock Lines Sue & Larry Gear and Maintenance Articles 0 08-12-2002 08:00 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
